  • Page:
  • 1
Vibration at high speed 20 Sep 2014 18:18 #648215
  • Zagg
  • Zagg's Avatar Topic Author
  • Thank you received: 0
I just bought a 1980 KZ1000 (E2?). It has been modified with pod filters and 4 to1 Vance and Hines exhaust etc. I discovered at speeds over 65 mph (around 5000 rpm) it starts to vibrate badly to the point I feel unsafe. The vibration is so bad that I can’t see out of my rearview mirrors, my Speedo/tack is hard to read and my hands go numb. I’m hoping this is not normal, it runs great at speeds below 65.
Vibration at high speed 20 Sep 2014 22:00 #648235
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
Check tires/wheels for balance first. ;)
Vibration at high speed 20 Sep 2014 22:24 #648237
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
  • Thank you received: 63
I would also wonder and check the chain and both sprockets for wear.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Vibration at high speed 21 Sep 2014 02:54 #648242
  • peter1958
  • peter1958's Avatar
  • User is blocked
  • Thank you received: 198
Tighten engine mounts to spec.
The following user(s) said Thank You: PLUMMEN
Vibration at high speed 21 Sep 2014 06:13 #648248
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
Probably old tires
78 KZ1000 A2A
Vibration at high speed 21 Sep 2014 11:37 #648269
  • MFolks
  • MFolks's Avatar
  • Thank you received: 540
May not apply to your problem, but some places to check:
I copied this from a post from Jeff Saunders (owner of Z1 enterprises)
Motorcycle Wobble Causes
There's a LONG list of potential area that can cause this.
These are not in any particular order
Wheel bearings
Steering bearings - repack grease, check tightness
Swing arm bushings/sleeves/bearings - replace if worn, repack grease
Fork springs aging - check spring length
Unequal fork oil - if seals leak, then your damping can be ineffective
Rear shocks aging, damper leaks - if you have oil leaking from the seals, the damping is toast.
Worn Tires/Mismatched tires/tire pressures/wrong size tires
Wheel alignment - don't trust the chain adjusters - I visually align the wheels.
Bent rims/broken spokes - get the wheels off the ground and
spin them - check for runout / damage
Front disc warped - check for runout
Steering & swing arm bearings are very common problems, but so are tire issues (pressure/mismatch) and wheel alignment.
Not having a front fender, as it helps stiffen up the forks. I’d suggest a fork brace.
Vibration at high speed 21 Sep 2014 13:36 #648274
  • Thank you received: 2829
Try this - accelerate up to 5000 rpm in 3rd gear then do it again in 4th gear. In each case the bike will reach a speed of something under 65 mph. If the vibration still occurs at around 5000 rpm the problem is most likely engine related. If the problem doesn't occur it probably is related to tires or other running gear rather than the engine since it seems triggered by the speed of the bike rather than the speed of the engine . Ed
Vibration at high speed 21 Sep 2014 16:02 #648295
  • etbike3135
  • etbike3135's Avatar
  • Thank you received: 50
Front tire. Too small or just a crappy one.
1973 Kawasaki Z1
18 years in dragbikes
Vibration at high speed 21 Sep 2014 16:35 #648298
  • KZTRIP
  • KZTRIP's Avatar
650ed wrote: Try this - accelerate up to 5000 rpm in 3rd gear then do it again in 4th gear. In each case the bike will reach a speed of something under 65 mph. If the vibration still occurs at around 5000 rpm the problem is most likely engine related. If the problem doesn't occur it probably is related to tires or other running gear rather than the engine since it seems triggered by the speed of the bike rather than the speed of the engine . Ed
thats quite a logical approach, I like it
89 KZ1000 Police (fully dressed)
96 KZ1000 Police (fully dressed)
86 KZ1000 Police (Parts bike, parts available for sale)
04 Ninja 250
Vibration at high speed 21 Sep 2014 17:33 #648300
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
Had this one mine, turned out to be a badly repaired alternator rotor which was out of balance,
The following user(s) said Thank You: peter1958
Vibration at high speed 22 Sep 2014 23:13 #648437
  • FaultedGeologist
  • FaultedGeologist's Avatar
  • The truly educated never graduate...
  • Thank you received: 7
Go with what 650ed said first, then let us know the status. The long list by Jeff Saunders is pro knowledge.
My bike has something of a vibration around 4,500 rpm up to 5k, then it goes away. A local tech said something is rattling at that harmonic frequency. He said it may be exhaust pipe, etc. I may check my engine mounts to see.
Bike should be enjoyable to ride, that sounds really bad.
Clint a.k.a. Faulted Geologist
1980 KZ750 LTD H4
FSMaunual: kz.bike-night.com/media/GPz750-full.pdf
Stock except for:
New chain and sprocket (530?).
Dynatek Ignition
NO PHILLIPS HEAD SCREWDRIVERS!!
kzrider.com/forum/10-new-members/603905-new-member-kz750-1984-project#742729
  • Page:
  • 1
