  • Page:
  • 1
oil cooler question 12 Sep 2014 18:09 #647305
  • NapalmZ
  • NapalmZ's Avatar Topic Author
  • work while bent
  • Thank you received: 5
So I have an windjammer on my 76kz900 and I wanted to remove it and go back to the stock headlight.
My problem is the fact that i have a oil coolant system installed to the windjammer. So before i bypass or spend hours manufacturing a custom bracket or the cash to buy a compatible bracket, how much do i need it considering i will be rarely riding my bike more than 45 minutes at a time in 110* weather max during the summer which is not extremely common in Sacramento ca?
if in decide to do away with it do i just cut the hose and run run it strait back into the port bypassing the radiator?
1976 kz900 a4 with delkevic 4 in to 1
oil cooler question 12 Sep 2014 18:18 #647306
  • bountyhunter
  • bountyhunter's Avatar
  • Thank you received: 337
The stock bikes never had an oil cooler so I doubt it's mandatory. You can always change to real synthetic oil if you are concerned about oil breakdown.
"if in decide to do away with it do i just cut the hose and run run it strait back into the port bypassing the radiator?"
Not sure about that. I would think you'd want to go back to the stock fittings if they are available. I think the aftermarket coolers put a different fitting with hose at the location of the oil pressure sending unit out to the cooler with a return fitting and hose at the bottom of the oil pan (?)
oil cooler question 12 Sep 2014 18:23 #647308
  • NapalmZ
  • work while bent
give me 20 to charge my phone and ill take a pic.
EDIT:bike has been running synth since 76'
Last edit: by NapalmZ.
oil cooler question 13 Sep 2014 06:56 #647341
  • NapalmZ
  • work while bent
allot of shit happened last night when i went to take pics.
oil cooler question 13 Sep 2014 08:06 #647347
  • kaw-a-holic
  • kaw-a-holic's Avatar
  • Thank you received: 248
I think the stock fitting is the same. I'm about to put a oil cooler on my bike. its a 77 KZ1000. I'll look to see if its the same part # and get back to you. Maybe we can trade some parts, or you can buy mine out right.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
oil cooler question 13 Sep 2014 08:17 #647348
  • kaw-a-holic
as much as I HATE referring folks to Partzilla, here is a link to the parts diagram if you want to do it right. www.partzilla.com/parts/search/Kawasaki/...HER+COVER/parts.html
You will need parts 2, 3,4,5,21 & 22
Jon
1977 KZ1000a1
Mesa, AZ
oil cooler question 13 Sep 2014 10:53 #647362
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
kaw-a-holic wrote: as much as I HATE referring folks to Partzilla, here is a link to the parts diagram if you want to do it right. www.partzilla.com/parts/search/Kawasaki/...HER+COVER/parts.html
If you really hate that site, you can always refer to the official Kawasaki parts diagrams
www.kawasakiepc.com/SystemSearch_Frames....594&CFTOKEN=76118312
oil cooler question 13 Sep 2014 12:59 #647382
  • NapalmZ
  • work while bent
i was not indenting on completely eliminating the oil cooler and windjammer, considering i may be riding from Sacramento to Portland next year when the bike is done, and i want to keep them for long rides like that.
EDIT: so, let me reiterate the question with some clarity, do i need the stock setup or will the bike be fine with just a hose?
oil cooler question 13 Sep 2014 16:05 #647406
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
hose will be fine
oil cooler question 13 Sep 2014 22:09 #647451
  • NapalmZ
  • work while bent
Street Fighter LTD wrote: hose will be fine
thank you
Re:oil cooler question 19 Sep 2014 20:35 #648121
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
  • Thank you received: 75
Your cooler will mount up to the frame np. I'd keep it on. Always a good thing.
79 LTD B3
  • Page:
  • 1
