'82 KZ750/'82 GPz750 Oil Pan Compatibility?
  • KraZyRIDER
  • KraZyRIDER's Avatar Topic Author
12 Sep 2014 06:27 - 12 Sep 2014 06:28
#647230
...Are they the same except for the black paint?
...Comparing photos, they look the same. Oil switch, oil line hook up, all that. Anyone know for sure?
...Thanks in advance. :)
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
Last edit: 12 Sep 2014 06:28 by KraZyRIDER.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: '82 KZ750/'82 GPz750 Oil Pan Compatibility?
12 Sep 2014 07:16
#647233
The E model shouldn't have an oil switch on the bottom of the pan, while the GPz's do. Is your 1982 750 a non-E model?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: KraZyRIDER
  • baldy110
  • baldy110's Avatar
12 Sep 2014 08:11
#647240
It will bolt right on.
  • KraZyRIDER
12 Sep 2014 08:18
#647243
I've got parts and someone is looking for a GPz type pan. GPz I don't have, several KZ750 I do have. The KZ750 pans I've seen have a switch in them. I think I'll check with him, it sounds like he's trying to hook up an oil cooler on a bike (maybe a 650) that doesn't have a cooler. I just need to know if the KZ750 pans with the switch will interchange with a GPz pan. Thanks.
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
  • koolaid_kid
  • koolaid_kid's Avatar
12 Sep 2014 12:41
#647273
The 83 GPz pan has the fittings for the oil cooler. That may be what he is looking for.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • baldy110
  • baldy110's Avatar
12 Sep 2014 13:48
#647283
Yes it will, the GPz pan has the oil level sending unit in the pan. I installed a GPz750 pan onto my KZ650 for the oil cooler. Fits like it was made for it, pretty cool mod. I simply guttet the oil sending unit and used it as a plug for the hole.
[IMG
[IMG
  • KraZyRIDER
12 Sep 2014 15:42
#647297
...Thanks! I though so, just wasn't 100% sure on that.
...I'm sure that's what this person is trying to do.
...Thanks again! :)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
  • Nessism
  • Nessism's Avatar
13 Sep 2014 06:56
#647342
baldy110 wrote: Yes it will, the GPz pan has the oil level sending unit in the pan. I installed a GPz750 pan onto my KZ650 for the oil cooler. Fits like it was made for it, pretty cool mod. I simply guttet the oil sending unit and used it as a plug for the hole.
[IMG
Nice clean install here.:D
I bought a later pan with the cooler take offs and cooler from a ZR-7 for install onto my 750E2. The cooler is quite a bit larger than the early cooler and I'm concern about clearance and mounting. At any rate, hope it integrates as nicely as this one. Well done.
The following user(s) said Thank You: Newimperial
