Nessism wrote: A few things here...
The tip of that one pilot screw may be stuck in the carb body, blocking all flow though the pilot circuit. You best tend to that. It's critical to not bottom out the screws too hard or stuff like that happens.
I checked for the tip of the pilot screw. The hole originally did not show light through it. I ran a pin through it from the bottom, up through to the top, and it cleared out. I never found the tip of it. I was uber gentle with the needles when screwing them in before backing them out so I find it hard to imagine I did the breaking, but the break point did look fresh.
Nessism wrote: It's critical that the carbs are 100% clean before attempting to tune them. After 33+ years the rubber O-rings tend to get hard and brittle too, and not seal too well.
I replaced all the rubber o-rings on the carbs with the rebuild kits, and used the new pilot screws just last night.
Nessism wrote: You can't tune an engine that is in need of general purpose maintenance. In particular, things like valve adjustment and vacuum carb sync. The intake system is sensitive to air leaks too and having a proper air filter in the airbox. Do all maintenance before attempting to fine tune the bike.
The guy at the bike shop said I needed to get the air fuel mix set before doing a vac carb sync. Valves would be nice to check, but bike ran great before digging in to the carbs when they were pissing gasoline. Do I need a new valve cover gasket if I check valve clearance? A new gasket is what is holding me back on checking... Have original air filter, new airbox boots.
Nessism wrote: General process is to tune pilot screws for the highest idle setting. Again, you can't do this until the other maintenance is tended too though. At any rate, adjust each screw until the highest idle is achieved. Sometimes the idle doesn't respond to screw adjustment, in which case just leave the screws at about 2.5 turns open. This is a safe setting and shouldn't cause issues.
They should all be set around 2.25 turns now, with the 3rd set around 3.5ish just to get it to warm the exhaust. I am wondering why it seems to run worse with cylinder 3 firing now (at least heating up the exhaust pipe). It should be running much better with all 4 firing...
