Comparison of Headers
  • 4TheKZ1000
  • Topic Author
  • Visitor
29 Sep 2012 22:23 - 29 Sep 2012 22:44 #551606 by 4TheKZ1000
Comparison of Headers was created by 4TheKZ1000
whats the differance between a Vance & Hines Sidewinder and this Vance & Hines Pro-Pipe? both are intended to fit kawasaki kz 1000
Thankyou....Spencer
Attachment vhpropipe.jpg not found
Attachment ZA44017_A.jpg not found
Last edit: 29 Sep 2012 22:44 by 4TheKZ1000.
  • wireman
30 Sep 2012 01:58 #551637 by wireman
Replied by wireman on topic Comparison of Headers
Probably tube size,top tubes look bigger might need a front end rake also. B)
The following user(s) said Thank You: BlackZ1R, 4TheKZ1000
30 Sep 2012 09:38 #551650 by les holt
Replied by les holt on topic Comparison of Headers
I believe the sidewinder requires a rake also. Can't say for sure, never tried to mount one on a non raked bike.
Les
The following user(s) said Thank You: 4TheKZ1000
  • 4TheKZ1000
  • Topic Author
  • Visitor
30 Sep 2012 10:42 - 30 Sep 2012 12:49 #551659 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Comparison of Headers
wireman wrote: Probably tube size,top tubes look bigger might need a front end rake also. B)
If you look close....you can see a double wall at top opening of header. Could explain the bigger size?
I cropped the photo and expanded the photo....its not a double wall just a wire going across to hold mounting flange in place.... :sick:
Last edit: 30 Sep 2012 12:49 by 4TheKZ1000.
30 Sep 2012 10:56 #551660 by les holt
If your looking at e-bay adds I believe they are selling the same header, just wording differently. The pro pipe does say small tubed and pic is not actual part. You may contact them to clarify what they are actually selling. If it's the same, someone sells it for around $211 if you look around.
Les
  • wireman
30 Sep 2012 12:47 #551673 by wireman
That top pipe would lok good in under a piece of glass in my living room! :woohoo:
30 Sep 2012 17:11 #551715 by kzz1king
Replied by kzz1king on topic Comparison of Headers
There website was no help to me :S
Wayne
Home built KZ1000 turbo setup
30 Sep 2012 17:45 #551719 by etbike3135
Replied by etbike3135 on topic Comparison of Headers
Yeah, I dont think that top picture is what your getting. I have not seen a new pipe like that in years.
1973 Kawasaki Z1
18 years in dragbikes
30 Sep 2012 18:00 #551724 by zukdave
Replied by zukdave on topic Comparison of Headers
The top pipe IS NOT a KZ pipe.
Look at the angle of the flange at the head.
As for the other one Yes with some easy mod.'s
it will fit with out raking the frame.
I put one on my 1980 650f1 today.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
30 Sep 2012 20:22 #551741 by LarryC
Replied by LarryC on topic Comparison of Headers
Look at the angle of the primary tube entrances in the top one. You're not bolting that to a Kawasaki OEM head..
Larry C.
  • 4TheKZ1000
  • Topic Author
  • Visitor
30 Sep 2012 20:47 #551744 by 4TheKZ1000
well I guess that ends it....not a KZ header....I couls swear Ive seen several on KZ bikes.....will call Vance & Hines to ask....I need to see if they will replace my Megaphone that cracked at the weld....
Attachment 015.JPG not found
  • 4TheKZ1000
  • Topic Author
  • Visitor
30 Sep 2012 20:48 - 01 Oct 2012 22:05 #551745 by 4TheKZ1000
double post
Last edit: 01 Oct 2012 22:05 by 4TheKZ1000.
