COILS
  • JEFFG1
  • JEFFG1's Avatar Topic Author
COILS
25 May 2012 16:08
#524752
WONDERING IF IT MATERS WHAT OHM COILS YOU USE I JUST HAD A COIL GO OUT AND HAVE TO GET NEW ONES THEY ARE GREEN 3 OHM DOES IT MATTER IF I WAS TO PUT 7 OHMS OR SHOULD I STICK WITH THE KIND I HAVE I WILL REPLACE BOTH OF THEM???
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: COILS
25 May 2012 16:19
#524754
What kind of ignition system are you running? I believe certain ignition systems can only handle certain coils. I have a Dyna2000 and it can handle 2.2ohm (what I have) and 3ohm but not .7ohm IIRC.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: COILS
25 May 2012 16:25
#524755
StreetfighterKz wrote: What kind of ignition system are you running? I believe certain ignition systems can only handle certain coils. I have a Dyna2000 and it can handle 2.2ohm (what I have) and 3ohm but not .7ohm IIRC.
Later, Doug
X2
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • JEFFG1
Re: COILS
25 May 2012 16:33
#524756
thats what i have to dyna 2000 so i better get what i had thanks
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: COILS
25 May 2012 17:35 - 25 May 2012 17:36
#524772
the Dyna2000 can use the 2.2 grey coils, wich provide a little more zap that the 3 ohm greens.
if its time for new coils u may as well get the grey ones. try Z1e.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 25 May 2012 17:36 by mark1122.
