125 hp. How?
- mtbspeedfreak
125 hp. How?
24 Aug 2011 16:08
Alright, I'm eyeing up a basketcase '77 KZ1000 for a long-term project. I'm envisioning a street bike that's just about squeezed to the max (but not all the way).
Cams, carbs (smoothbores), big-bore kit, proper porting (maybe a GPZ head?), Yosh pipe (maybe a titanium hand-bent replica
), etc.
Modern suspension (I'd love a conventional fork and to keep the dual rear shocks), brakes, wheels and tires.
You know the drill, nothing too gaudy, but something that'll stand out in a crowd.
If you wouldn't mind sharing, what have you done to your engines? As much detail as possible would be beneficial: cam numbers, hp at the crank/wheel, carb size, cc's, porting job, etc. I'm thinking 125 is a nice round number that doesn't seem like it's unattainable. 125 hp at the crank of course.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- T_Dub
Re: 125 hp. How?
24 Aug 2011 16:15
Send your engine to Larry Cavanaugh, tell him what you want, you'll get it, and at a reasonable price. Plus it'll come back looking better than new.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Kidkawie
- I bleed premix
- mtbspeedfreak
Re: 125 hp. How?
24 Aug 2011 16:55
No thanks, I like my power naturally-aspirated. No turbo, supercharger or nitrous.
2000 ZRX 1100
- mark1122
- Keep twisting it
Re: 125 hp. How?
24 Aug 2011 17:23 - 24 Aug 2011 17:41
Sandy, a member here, has a front and rear end from a zrx11 for sale.
i used a zrx12 rear end and a zx9 front end.
MTC 1200cc,rc400cams,Larry's porting,37.5mm intakes, RS34's,back cut trany,billet 2nd gear, MK11 crank, Dyna2000,& coils,Earl's 13row cooler.
not sure of the HP. 5 or 6 maybe ?
I hope this isnt too gaudy
Attachment newbestrt.jpg not found
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 24 Aug 2011 17:41 by mark1122.
- DFIGPZ
Re: 125 hp. How?
24 Aug 2011 21:29
125hp not a problem with the RIGHT combination of parts and proper assembly a "J" head would be a help for sure but this can be done with a KZ style head with out issue.
1984 750 Turbo
- cavanaughracing
Re: 125 hp. How?
24 Aug 2011 21:46mark1122 wrote: Sandy, a member here, has a front and rear end from a zrx11 for sale.
That paint job turned out so sweet
Larry C.
cavanaughracing.com
cavanaughracing.com
- trianglelaguna
Re: 125 hp. How?
24 Aug 2011 21:53
wow ..crashing does wonders for your bike...you should try it more....the bike looks great
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- cavanaughracing
Re: 125 hp. How?
24 Aug 2011 21:55
Do you just care about reaching 125 HP or do you want a motor with some grunt all the way through too? There's more than one way to go about the process....depends on what you're after.
If you have the extra money, go straight to the 1197 bore.
A set of Joe's PSP3x cams or Cam Motion Z4's in combination with a good head and some RS36's will make a 1075 motor haul that kind of ass but it won't have the grunt the 1197 will below 5K.
Jay's K435's will straighten your arms out and make you take notice if you don't mind going Shim Under for the valve adjustment.
Web's got a bunch of grinds that will do the job.
But know this, If you rode a hyped up 1075 then got off that and immediately onto an 1197 that was set up with less cam and a great head...you'd forget all about the 1075....trust me.....or don't
Larry C.
cavanaughracing.com
cavanaughracing.com
- trianglelaguna
Re: 125 hp. How?
24 Aug 2011 21:57 - 24 Aug 2011 22:01
slipper pistons--- pop tops..head work,valves, cams...modern 29's..light rims..530 conversion...hd clutch..gearing work....same thing as putting 125 into one without those items..maybe even faster...
EDIT: typed while Larry C was posting his reply..mine is a reply to the orig question imho and not in respsonse to larry who posted just before mine
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
Last edit: 24 Aug 2011 22:01 by trianglelaguna.
- Kidkawie
- I bleed premix
Re: 125 hp. How?
24 Aug 2011 23:15
You can buy a modern 600 too. lol
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- testarossa
Re: 125 hp. How?
24 Aug 2011 23:31Kidkawie wrote: You can buy a modern 600 too. lol
That option definitely won't have the grunt below 5000 rpm, but they scream all the way to 16,000.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
