Rythmic ticking.... 750-4
- apbling
25 Apr 2011 23:44
1980 750-4 LTD.
Took a spin today. Bike runs great and strong. Recent oil change, valve clearances in spec, stock airbox and dunstall slip on pipes.
At idle the bike is purring just fine. I can hear the valves ticking, but nothing extreme. Then, a rythmic ticking becomes noticeable, gets louder, goes away...all within 3 seconds. Wait maybe 5-10 sec and it does it again. Can't tell where its coming from, but if I had to guess I'd go with the top end. Any ideas? The rythmic style really baffles me...plus its a slow ticking, maybe 4 ticks/sec, so it seems slow to be associated with any cam/valve noise.
It's done this the entire time I've owned the bike and I only notice it at idle.
- sparkn
Re: Rythmic ticking.... 750-4
26 Apr 2011 11:12 - 26 Apr 2011 11:27
Stupid ideas. Just rambling...
Is it doing it on the kickstand? What about off the kickstand or leaning to the other side? If you plug the emissions, does the noise go away? Increase the rpm's slightly. Still hear it? On your favorite road at your favorite speed on a beautiful day with only the best of friends while passing a Harley, are you still reminded of it?
Seriously, the only one I'd probably check is idle. Bump it slightly and if the noise goes away then forget it like it never happened.
1979 KZ650 SR
Last edit: 26 Apr 2011 11:27 by sparkn.
- Tyler
26 Apr 2011 11:58
two things come to mind.
1. If you haven't removed the emmissions stuff form the valve covers. It could be the reed valves in the valve covers clicking. That could be kind of random.
2. If your running the stock cam chain tensioner I would remove it immediatly. Could be tesioner is periodically slipping and the chain is clicking. I would be leary of the tensioner letting go.
"74 Yamaha DT 400 Enduro
- apbling
26 Apr 2011 12:01
hehe, I did just that. (the harley part) They were just getting on their bikes after sitting in a tavern all day (why have the bike anyway?).
As for the questions: does it kickstand or none. no difference with the leaning. Never thought of the emissions... I'll have to increase the RPMs once and try it. It's subtle enough you don't hear it while revving, but I bet if I just increase my idle speed to 2k or so I could still hear it.
And to have a gem like this bike for $300, no, I quickly forget about it at times.
- dshelly
26 Apr 2011 12:12
When is the last time you adjusted you cam chain tensioner? That's what I think it sounds like .
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- apbling
26 Apr 2011 13:22
Well, I have verified several times that the tensioner works (off the bike of course), but how well I don't know. It's the automatic two wedge tensioner type... Been meaning to upgrade, but just a tightwad...
- apbling
26 Apr 2011 13:28
Is my only option the APE one? Just seems pricey for what you get. Did maybe one of the older bikes have a manual one that could fit?
- mjg15
26 Apr 2011 16:09
Maybe you could use one from a "new" generation ZR750
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- Tyler
26 Apr 2011 16:21apbling wrote: Well, I have verified several times that the tensioner works (off the bike of course), but how well I don't know. It's the automatic two wedge tensioner type... Been meaning to upgrade, but just a tightwad...
I said the exact same thing about my 650, untill it failed on me one day. I was lucky a was a block away from home and limped in. It didn't completely let go but it loosed up a lot, the sound was NOT something I care to hear again.
Buy the part form APE and be done with it.
- apbling
- sparkn
26 Apr 2011 18:24
Would just the tensioner on the outside of the engine be necessary or parts inside the head also? I'm assuming just the exterior bolt on piece but I'd like clarification. I'm considering this also for my '79 650.
1979 KZ650 SR
- apbling
27 Apr 2011 17:41
I've never had the head off and inspected anything... That would be a kind of expensive little exploratory surgery...
