No kicker to kicker?
  • lobstermobster
  • lobstermobster's Avatar Topic Author
02 Mar 2011 20:31
#434539
Might be a pretty dumb question,but.....
I have an 81 650 with no kicker. Would love to get rid of that stupid battery. Are there any other models of same or compatible years with a kicker that would be an easy install or is this just the dumbest question you've ever heard?
1981 kz650 w/ flux capacitor
  • kawman14733
  • kawman14733's Avatar
Re: No kicker to kicker?
03 Mar 2011 05:36
#434566
your electronics will still need battery
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
03 Mar 2011 06:06
#434573
But you have button to button. :laugh:
You will still need the battery to maintain a smooth constant voltage to your electronics/ignition/lighting, etc.
It is complicated, but doable - to have a no battery system. But it consists of installing a large capacitor and new wiring and such.
That bike doesnt even have the kicker internal gear on the clutch right??? nor the other gearing and kicker sprocket?? That would be a huge pain to fab!
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
03 Mar 2011 06:20
#434576
I have a 650 engine for 100 bucks. Roy
  • martin_csr
  • martin_csr's Avatar
Re: Kick starter conversion
03 Mar 2011 06:27 - 11 Feb 2013 13:20
#434578
See following reply by OnkelB w pics
Last edit: 11 Feb 2013 13:20 by martin_csr.
  • DoubleDub
  • DoubleDub's Avatar
03 Mar 2011 06:30
#434579
heh heh orifice
  • OnkelB
  • OnkelB's Avatar
03 Mar 2011 07:24 - 03 Mar 2011 07:28
#434593
Don't know much about going battery-less, but installing a kickstart can be done, whether it can be done easily or not depends on your definition of easy - in order to install the kickstart shaft and the stopper plate you need to split the cases, no way around that.
You will need the parts pictured below (stopper plate included) as well as a kickstart model clutch cover and the kickstarter itself.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 03 Mar 2011 07:28 by OnkelB.
  • TeK9iNe
  • TeK9iNe's Avatar
03 Mar 2011 10:59
#434665
DoubleDub wrote:
heh heh orifice
:laugh: hehe
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • PLUMMEN
  • PLUMMEN's Avatar
03 Mar 2011 11:05
#434668
is there a place to mount kickstarter? B)
  • lobstermobster
03 Mar 2011 16:15
#434768
well according to my definition of easy,... that doesnt sound to easy. ill take a look at my bike and snap a photo or two of what im working with. ive never been inside an engine really, still learning.
  • steell
  • steell's Avatar
03 Mar 2011 19:34
#434825
As usual OnkelB has it right.
I just recently sold a 750 four motor that had been swapped over to a kickstarter. Only one I've ever actually seen.
  • lobstermobster
10 Mar 2011 18:16 - 10 Mar 2011 18:19
#436900
heres a pic of what im working with, well just the outside of it. it looks like the place where the kicker would be is just covered up. by splitting the cases, do you mean taking the cover off... or taking my whole engine out of the frame and completely taking the bottom end apart?
Last edit: 10 Mar 2011 18:19 by lobstermobster.
