Hi-vo Chain and Cam Degreeing/ Tool or Home made
  • Motor Head
  • Motor Head's Avatar Topic Author
10 Jan 2011 14:31 - 10 Jan 2011 15:21
#421264
I'd like to see what the guy's are using to hold down the cam chain while they degree in their cams when the Hi-vo chain is in place. Snubber/ guide block being in the valve cover of course, instead of a Idler wheel.
Just cut up a old cover? Or whats the other used methods? As without the guide pressuring down on the chain, the intake cam will be lost and not found.
Just seeing whats out there in use.
Last edit: 10 Jan 2011 15:21 by Motor Head.
  • kzz1p
  • kzz1p's Avatar
  • One Test Is Worth A Thousand Expert Opinions!
Re: Hi-vo Chain and Cam Degreeing/ Tool or Home made
10 Jan 2011 15:26
#421283
Here's a picture someone posted a while back.
  • Motor Head
10 Jan 2011 15:30 - 12 Jan 2011 11:51
#421286
Good, I figured get a cheap cover and cut it would be 1 and probably the cheapest way to get good access.
Thanks.
EDIT: If some one has a 81 up "J" 1000/ 1100 valve cover with road rash or cracked they want to see go to good use, I'll pay the post. Thanks.
Otherwise I'll build something.
Last edit: 12 Jan 2011 11:51 by Motor Head.
