piston to cylinder clearence cast vs. forged?
  • kawi810
  • kawi810's Avatar Topic Author
18 Dec 2010 08:13
#417572
what is the ideal clearence for forged wiseco pistons(k810).just reringing my 810 and after hone i have about .004" is this too much should i have another cylinder bored out?
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
  • APE Jay
  • APE Jay's Avatar
Re: piston to cylinder clearence cast vs. forged?
18 Dec 2010 10:22
#417587
.0015 to .002". .004" is way loose.
  • bountyhunter
  • bountyhunter's Avatar
18 Dec 2010 11:42
#417613
Is the .004" at the bottom or top of the piston? They are tapered from top to bottom, widest at the bottom.
  • kawi810
18 Dec 2010 15:41
#417641
yea it`s at the bottom of the skirt. too lose ok
  • kawi810
18 Dec 2010 15:47
#417642
so a rebore with about .002" piston to cylinder clearance .is this average for forged pistons?
  • APE Jay
  • APE Jay's Avatar
18 Dec 2010 23:02
#417672
It depends on how the piston is made and what it is made from. my answer was for a Wiseco
  • kawi810
19 Dec 2010 07:50
#417708
are cast pistons set up tighter then forged?
  • APE Jay
  • APE Jay's Avatar
19 Dec 2010 14:42
#417760
Yes. However, Wiseco uses a high silicon 4032 material and can run almost as tight as a cast piston.
2618 material used by most others has to run with more clearance.
  • kawi810
20 Dec 2010 15:39
#417928
thanks for the info .i have been told for years that you have to run wisecos loose because they expand alot . just trying to seperate fact from urban legend. if anybody else has experiance with running to tight or to loose p/c post it please.
  • timebomb33
  • timebomb33's Avatar
20 Dec 2010 15:59
#417934
on my street motors i use the wiseco spec's on my race motors i go about .001 looser just because they don't get as much chance to warm up fully
I THINK MY POWERBAND BROKE
  • APE Jay
  • APE Jay's Avatar
20 Dec 2010 21:55
#417994
The opposite is true with Wiseco.
  • steell
  • steell's Avatar
21 Dec 2010 11:50
#418067
Says the man who has probably sold and installed more Wiseco motorcycle kits than anyone else in this country.
