GPZ750/810 racer running....
  • turboguzzi
  • turboguzzi's Avatar Topic Author
05 Nov 2010 15:03 - 23 Jul 2017 20:08
#410994
After doing a lot of talking, here are the first steps in my Vintage racer build.
It's going to compete in the open class in the Italian Vintage championship. It's going to be up against big 1100 Zed's and Sozooks but as we dont have many horsepower tracks in the calendar, hopefully the quicker, more modern handking handling will make a difference.
Let's start with some frame bracing then?
bottom top tubes are now braced to the top one and also felt like adding to side supports to the steering head that was sticking out so much
Last edit: 23 Jul 2017 20:08 by KZQ.
  • turboguzzi
Re: GPZ750/810 racer marching on
05 Nov 2010 15:10
#410996
another shot showing smal triangulation under new tubes
  • turboguzzi
05 Nov 2010 15:12
#410997
planning to use the two bottom holes in the cases (they will bolt to those two new ears) as well as going for rigid mounts instead of the rubber ones
  • turboguzzi
05 Nov 2010 15:15
#410998
above the rear cross tube i welded four ears. gonna bolt to them a1/8" ally plate to make that area more rigid, that plate will serve also as the carrier for the total loss ignition battery
  • turboguzzi
05 Nov 2010 15:20
#411000
last, never like the idea of the left engine spacer being bent by the chain tension, ite welded to the frame now + a msall bracket transfer loads to the rear cross tube.
all in all, about 1 pound of gusseting added, but have removed about 3 with all the those brackets and spacially THAT side stand bracket!
  • turboguzzi
05 Nov 2010 15:21 - 05 Nov 2010 15:22
#411002
bosses for the race stand bobbins welded to the s'arm...
Last edit: 05 Nov 2010 15:22 by turboguzzi.
  • turboguzzi
05 Nov 2010 15:27
#411006
last, whiel at the welder's, filled up the side chamfers in the combustion chmaber, effectively "bathtubing" the chambers. this will let me to control better the squish areas as well as making them wider. as a bonus, chamber volume is smaller so yiu can get away with a less bumpy piston. head has been surfaced already, have to reprofile the inner side now.
  • steell
  • steell's Avatar
05 Nov 2010 20:42
#411104
KZ750 or 83-85 GPz750 head?
  • turboguzzi
06 Nov 2010 02:18
#411142
gpz 83
  • larrycavan
  • larrycavan's Avatar
06 Nov 2010 07:13 - 06 Nov 2010 07:20
#411174
Also a great way to screw up pressure recovery in the cylinder. ;)
I know what you're trying to accomplish but there's a down side to every up side & sometimes the hoped for improvement cancels out other important characteristics. JMO
Not trying to be a dink to you, it's obvious you're not a hack. Just something for an intelligent guy like yourself to consider...
Larry C
Last edit: 06 Nov 2010 07:20 by larrycavan.
  • Injected
  • Injected's Avatar
06 Nov 2010 07:35 - 21 May 2011 01:29
#411181
x
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 21 May 2011 01:29 by Injected.
  • turboguzzi
07 Nov 2010 09:00 - 07 Nov 2010 09:08
#411464
hi larry
not sure i understand what you mean by pressure recovery. can you explain?
I had pretty good results with a similar operation on my 500/4 racer, built a 0.2" wide, 0.03" thick squish area and was able to run 13:1 CR, 28-30 degs advance without any detonation. see pic
Would be interested to hear your recommendation regarding max CR for a road racing 810. We are allowed to use only pump super premium 98 octane + some additive, so all in all about 100 octane.
injected, not a bad idea, lets see if i find the place to do it.
Sure, if i had the means to scan the CC and then CNC each piston accordingly it could be great, but well above my means now. with this approach all i have to do is turn the pistons on a lathe for a flat external ring and then deck them to the desired squish.
TG
Last edit: 07 Nov 2010 09:08 by turboguzzi.
