piston top cleaning
- chrispysaki
piston top cleaning
20 May 2010 10:16
Can I use a wire brush to get the carbon off of the top of the pistons, or will it damage them?
Thanks!
Thanks!
- timebomb33
Re: piston top cleaning
20 May 2010 10:21
quickest and easiest way if there is a lot.the other option is to use gasket remover if its not completly baked on.when using a wire wheel dont concentrate in one area too long and be carefull around the ring lands
I THINK MY POWERBAND BROKE
- BSKZ650
20 May 2010 10:22
a wire brush is fine, I also would use some carb cleaner, it will help loosten the hard carbon, not knowing if you have the pistons off or how you are working on them, just be careful around the ring lands
77 ltd1000, current rider
76 kz900, just waiting
- BSKZ650
20 May 2010 10:23
timebomb33 wrote:
dang it,, fingers wernt fast enough,,lol
- timebomb33
20 May 2010 10:24
got to be quick around here brother.
- otakar
20 May 2010 11:12 - 18 Sep 2010 14:12
Best and quickest way to clean them is while they are still in a running engine, just bu using combustion chamber cleaner.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 Sep 2010 14:12 by otakar.
- otakar
20 May 2010 11:14 - 20 May 2010 11:15
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 May 2010 11:15 by otakar.
- otakar
20 May 2010 11:16
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- stonemaster
20 May 2010 11:34
BSKZ650 wrote:
+1 on that using some today on mine
- chrispysaki
20 May 2010 11:39
Wow, Okatar, can't argue with that! Where do you buy that combustion chamber cleaner?
20 May 2010 11:41 - 20 May 2010 11:46
Besides the spray-can products used by spraying into carbs while engine's running, other products are just added to fuel supply.
PBBlaster sprayed or poured through spark plug holes into combustion chamber, and allowed to soak for awhile, supposedly allows the carbon buildup to be blasted out the exhaust when the engine is next run. Or perhaps sprayed into carbs on running engine until engine dies, let sit for awhile to soak inside combustion chambers, then crank and run engine.
Sometimes water mist is sprayed into carbs while engine's running, to reportedly help blow out the built up carbon.
Results from the Mopar product (spray-can?) are impressive.
Wonder how the other products and water spray compare?
Last edit: 20 May 2010 11:46 by Patton.
- otakar
20 May 2010 11:57 - 20 May 2010 12:00
No eBay APP ID and/or Cert ID defined in Kunena configurationchrispysaki wrote:
I did a whole thread on this some time ago, I will try and find it and post a link. The one you see in the picture is from any Mopar dealer. Or you can buy it in different packaging on eBay from this guy. I bought a whole case because it was co cheap.
Here is one link, but I know there is another which I will try to find.
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=357990
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 May 2010 12:00 by otakar.
