Z1900 vs KZ1000 Transmission
  • supercharged
  • supercharged's Avatar Topic Author
16 May 2010 18:56
#368399
Are these 2 transmissions (gear sets) interchangeable? I know there was a change in the crank, but does that effect the trans?
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
  • zed1015
  • zed1015's Avatar
Re: Z1900 vs KZ1000 Transmission
16 May 2010 23:31
#368445
All the gear clusters are the same for the z900 - z1000 -z1r - and the mark 2 which had the bigger crank pins and more teeth on the cam chain drive.
It is the later J/GPZ style motor with no kickstart provision which uses a slightly modified and beefier cluster with larger dia output shaft.
This is not a straight swap without using a couple of different bearings and a spacer which can be bought from APE etc for this purpose as it is a popular mod with the race lads.
P.S. Wanna sell me your spare drouin drive pulleys ?:)
  • supercharged
17 May 2010 00:22
#368447
Thanks!
New PM sent.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
17 May 2010 14:59 - 22 May 2010 11:01
#368567
only the output shafts are dif. the z1 has a cotter pin hole in the end(witch can split). the kz shaft is the better 1. all parts are interchangeable.
after reading Jeff's post bellow, i stand corected. All the gears are not the same from a z1 to a KZ.
Thanks Jeff.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 22 May 2010 11:01 by mark1122.
  • PLUMMEN
  • PLUMMEN's Avatar
17 May 2010 19:36
#368645
kz1000/mkII motors have stronger gears
  • RonKZ650
  • RonKZ650's Avatar
17 May 2010 20:05
#368652
This is a rumor. All part numbers are the same on gears from a 1977 KZ1000 as they are on a MKII, so to me that means gears are not any stronger on the MKII.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
18 May 2010 08:27
#368730
Although Kawasaki retained the same part number, they did beef up the parts. I've not tried intermixing any of the parts, but when you put a Z1 gear cluster alongside a 80 KZ1000 gear cluster, you can see the difference.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
The following user(s) said Thank You: saxjonz
  • PLUMMEN
  • PLUMMEN's Avatar
18 May 2010 14:19
#368798
stick em side by side and tell me that :laugh:
  • RonKZ650
  • RonKZ650's Avatar
18 May 2010 14:28
#368801
OK I admit I may be wrong.:) Usually they do the exact opposite, having 5 identical parts with completely different part numbers.
The following user(s) said Thank You: kamakazie1000
  • Jeff.Saunders
  • Vendor
  • Vendor
19 May 2010 09:18
#369020
Ron, Kawasaki is VERY inconsistent when it comes to managing part numbers revisions.
Just on a 'simple' thing like the Z1 4-4 pipes. There are 4 distinctly different variants of the pipes - yet only one part number. Even a Z1 tank can be very different depending if it came on the bike, was purchased before 1976 or after 76... The changes are very noticable, but the part numbers remain the same. You even get a situation where the 73 Z1 replacement takes won't accept 73 tank emblems - yet the fiche make no mention of this.
Honda is very good about managing revisions - I wish kawasaki had done the same thing.
Kawasaki irks me with some of the changes they make - chrome parts become zinc finish. Nice chrome hex head bolts with a slight dome on the head become common 'home depot' zinc hardware with bolt grade on the top (but still the price as before). Order a Z1/KZ900 master cylinder cap and you get a very nice blue plastic cap these days...
In cases where Kawasaki issues a new part number as a supercession, there is no guarantee that part will be backwardly compatible. The KZ900 chrome lower fork covers will not fit the Z1, even though the xref says they will...
Z1 Ent on Facebook,
