Valve Timing issue
- kawasakibikefan
- Riding is a passion most do not understand.
Valve Timing issue
27 Apr 2010 05:23
I can not seem to time the valves correctly on my Z1B. This is what I have tried to do. I put the crankshaft mark on the 1/4 TDC mark. Then I put the white dot for the exhaust cam in place. It is lined up where the valve cover comes off and the small end of the triangle. But the exhaust is trying to push a valve down and making it really hard to keep the white dot there. Next I put the white dot onto the intake cam on the 28th tooth mark. This is where it gets hard. The cam chain has no slack and it is hard to get it to seat. I get it to seat and tighten everything down and turn the engine over slowly and I hit valve. I can only rotate the crank about 50 degrees. I am at a loss of how to do it.
'75 Z1B
'95 KLR250
My Future Buying List:
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- Old Man Rock
Re: Valve Timing issue
27 Apr 2010 05:27 - 27 Apr 2010 05:32
Your chain is most likely binding for it shouldn't be that tight.... See image on left for chain slack between timing gears...
The image on the right depicts where the cam lobe tips should be pointing in TDC 1/4... This image was taken from the right side of the engine....
Tips pointing at each other & parallel with the head decking....
Image on the left shows the intake cam off (Lob tip high)...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 27 Apr 2010 05:32 by Old Man Rock.
- Old Man Rock
27 Apr 2010 05:30
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kawasakibikefan
27 Apr 2010 05:31
I have chain slack when I tighten the cam caps down. It is pretty close to that picture. Its just when I am trying to seat the cams. Or should there still be plenty of slack then?
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- kawasakibikefan
27 Apr 2010 08:00
ok I figured out the timing part but I ran into another issue with it. I got all the slack like in the picture and the cams to look exactly like it. It was looking good until I started turning over the engine with my wrench. I got about 2 times around and it just froze. I checked my valves and non of them were down. So it must be something with the chain? I decided to go on through since it wasn't a valve and I heard my chain jump teeth. I used the automatic tensioner and thought I got the slack out. I guess not? So I am going to take it to a guy that knows how to time these engines and have him do it cause I just can not seem to get things right.
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- Beatpoet
14 May 2010 19:21
In case anyone from this thread is still listening, I thought I'd post my problem here because it is similar...
...Except I don't have any kind of mark whatsoever on my exhaust cam! I'm about to just try to match the picture in the book if I can't find one.
Any tips?
Any tips?
- mark1122
- Keep twisting it
16 May 2010 10:04
thats right , just follow the pics in the manual. the cam lobes must face oposite each other and have there centers line up with the valve cover surface.
the hardest part is getting the chain on the crank sprocket properly.make sure it is on the teeth and not alongside them.
good luck.
good luck.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
16 May 2010 17:33
Word of caution, insure what side of bike, what lobes your looking at, 1/4 TDC versus 2/3 TDC etc....
As mentioned in my images, this was taken from right side of engine and your looking at # 4 intake & exhaust lobe... As Mark mentioned, from the left side, lobes would be 180 out from each other...
Follow the manual and you can;t go wrong.... I think anyways...:blink: :S
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Beatpoet
Last edit: 25 May 2010 10:07 by Beatpoet.
