Changing oil 81' KZ1000
- Kitten Tooth
02 Apr 2010 13:47
Well, im changing the oil in my bike now since im waiting on my uncle to help me on saturday with the carburetors. I can't get the oil pan drain screw to break loose to drain all the oil out. I was wondering if maybe the threads were reversed or if there was an easier way to get it to break free than cranking on it with a socket wrench... I was also wondering where the oil filter was located. On my last bike, there was a circular cover on the front of the motor and the oil filter was under that. Is the filter located under the oil pan? Theres no cover on the front of the engine.
Thanks guys,
KT
Thanks guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- oldcoldankles
Re: Changing oil 81' KZ1000
02 Apr 2010 14:45 - 02 Apr 2010 14:46
They unthread when turned counter-clockwise when looking up from underneath. Best to use a 6 point socket so you don't round off the bolt heads. The filter is under a round cover beside the drain plug. Make sure you don't lose the steel spacer and spring. There is no need to over-torque these bolts.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
Last edit: 02 Apr 2010 14:46 by oldcoldankles.
02 Apr 2010 14:50
BFW, perhaps with an extension.
An impact wrench is even better since there will be less chance of busted knuckles or rounded bolt. The oil filter is under a round cover with a bolt in the middle of it. Yes, it is under the engine. The factory shop manual shows them clearly.
- Kitten Tooth
02 Apr 2010 15:16
thanks, thats all i needed to know:D
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
02 Apr 2010 15:16
check pm
