cam timing problems z1000 08 Aug 2009 02:11 #312347
  • MAFED
  • MAFED's Avatar Topic Author
  • Thank you received: 0
:( Hi all,
As part of the ‘restoration’ of my 1977 Z1000, I have refurbished the cylinder head valves etc. After fitting the cams and timing chain I rotated the crank by hand and guess what the cam timing is out even though I have followed the instructions to the latter; both cam marks line up with the cylinder head and the 28th pin mark lines up correctly, but every time I turn the engine after approx 350 degrees number 1 inlet valve begins to open as number 1 piston is just coming up to TDC!!!! Any body offer any help, should the cam lobes when setting the cam timing be horizontal or straight up as one other post suggested?
Many thanks
Stressed Z1000 owner
cam timing problems z1000 08 Aug 2009 06:29 #312356
  • Motor Head
  • Motor Head's Avatar
  • Thank you received: 391
Maybe I can help, Is your cams with the marks lined up to the valve cover gasket surface as you stated? Then the cams have a notch on the right end, these should be pointing EX to the front, IN to the rear also lined up with the gasket surface. Now if this looks right, I believe that when all marks are correct that you are not on the Firing stroke for #1 but 360 out. Most engines time this way. So you would see that you would be approaching valve overlap when you were looking at having your intake moving. Valve over lap is at TDC but with a 4 stroke engine TDC happens twice in a cycle. If it is done according to your book and it all turns freely, test your compression. It will suck if your timing is wrong. Just make sure that it all turns by hand before engaging the starter.:)
The following user(s) said Thank You: ErlingW
cam timing problems z1000 08 Aug 2009 07:16 #312360
  • RonKZ650
  • RonKZ650's Avatar
  • Thank you received: 237
Many times the wrong marks are used. Use this mark for exhaust.
cam timing problems z1000 08 Aug 2009 07:18 #312361
  • RonKZ650
  • RonKZ650's Avatar
Use this mark for intake. If you turned the engine over using any other marks, might as well disassemble now as you have bent valves.
cam timing problems z1000 08 Aug 2009 07:52 #312366
  • Old Man Rock
  • Old Man Rock's Avatar
  • Thank you received: 225
As Ron pointed out... also notice your cam lobe orientations....
NOTE: This is for a KZ900 head with performance cams and adjustable sprockets so yours may slightly be different but regarding the 28th tooth count and lobe orientations, should be reaaaaaaaaaaaal close...
This image is from the right side of the bike, pistons 1/4 TDC....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
cam timing problems z1000 08 Aug 2009 07:54 #312367
  • Old Man Rock
As reviewed in the above image, it's easy to be off in the lobe tip to head decking...
Corrected....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: by Old Man Rock.
cam timing problems z1000 08 Aug 2009 08:20 #312377
  • Old Man Rock
Your advancer may be different (Patton has an updated procedure for the KZ1000)....
Again, for a KZ900, seems to be ~ the same though....
I have the later advancer then depicted in the shop manual for mark alignment, otherwise should be ~ the same...
Please someone correct if incorrect!
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
cam timing problems z1000 08 Aug 2009 09:08 #312384
  • TerryK
  • TerryK's Avatar
We are on the right track here, but you MUST be absolutely certain you are on the right pin (28th). It's really easy to miss it by one.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: by TerryK.
cam timing problems z1000 08 Aug 2009 11:15 #312412
  • Thank you received: 2098
Likely see the style advancer shown below when seeking to align the T mark with the permanent case mark, used to fix the crankshaft at Top Dead Center incident to assuring correct cam timing.
Good Luck! :)
[Click on image to enhance view]
cam timing problems z1000 08 Aug 2009 14:47 #312445
  • MAFED
Hi Motor Head,
Great advice, it now begins to make a lot more sense! It seems the lobes are the key to this, it explains why the inlet valve is just beginning to open as #1 piston is coming up to TDC.
Many thanks
Mark:)
cam timing problems z1000 08 Aug 2009 14:49 #312447
  • MAFED
Hi Ronk,
Many thanks for the pictures and your sound guideance, will attemt to refit cams over next few days will keep you posted.
Cheers
Mark
cam timing problems z1000 08 Aug 2009 14:53 #312448
  • MAFED
Hi old man rock,
Your pictures explain it all! Thats where I am going wrong, I am looking at the lobes being symeetrically opposite each other, looking at this pic the inlet is slightly above the head.
Many thanks
Mark
