can you fit a kickstart to '81 kz750-4 ltd?
  • image
  • image's Avatar Topic Author
26 Dec 2008 01:26
#254698
if so what is required? is it a simple conversion of interchangeable parts? i did a bit of a search, but most conversation seemed to be about upping the 650 to 750 specs and removing the kickstart...
'81 KZ750-4 ltd / 810 GPz motor
'84 Suzuki GR650
'01 Ducati 750 Sport / corse pipes + chip
  • OnkelB
  • OnkelB's Avatar
Re: can you fit a kickstart to '81 kz750-4 ltd?
27 Dec 2008 04:56
#254828
I can't say for sure, but it might be possible to fit a 650 kickstart provided the 750 lower case has the hole for the kick start shaft and the mounting holes for the kickstart stopper plate and that the kickstarter gear fits the low gear on the output shaft of the 750.
You will need the parts in the pic below (650 kickstart assy disassembled), the stopper plate shown in the box in the bottom pic, the kickstart lever and a 650 clutch cover.
You will also have to split the cases, there's no way to get the kick start shaft in or out with the cases assembled.
77 KZ 650 B1, 82 GPz 1100 B2.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
27 Dec 2008 09:47 - 16 Jun 2009 19:35
#254912
The 750 case doesn't have the hole.
Edit: please add cover to the above statement.
Last edit: 16 Jun 2009 19:35 by JMKZHI.
  • steell
  • steell's Avatar
27 Dec 2008 11:54 - 27 Dec 2008 12:08
#254932
Are you really, really, really, sure about that?? :)
I assume we are talking about the hole in the case where the shaft fits, as in the above pic?
For your viewing pleasure, I present a KZ750 four right side lower case :)
It looks like everything is there :)
What to you think OnkelB? Look like all the provisions for kick start are there?
I don't have a 650 to compare, everything here is either a 750 twin or a 750 four.
Last edit: 27 Dec 2008 12:08 by steell.
  • kawsakiman
  • kawsakiman's Avatar
27 Dec 2008 14:35
#254958
you will also need a 650 clutch cover of course.
  • image
28 Dec 2008 06:13
#255061
cheers for the replies all.
ok, so essentially if the gearing and all the other variables mentioned are right, it should be possible? cool. definitely have to be a backburner project for the next time she's stripped right down though by the sounds of things, she's coming together far too nicely to want to pull apart again so soon!
thanks again.
'84 Suzuki GR650
  • OnkelB
  • OnkelB's Avatar
28 Dec 2008 10:34 - 28 Dec 2008 10:35
#255093
Sure looks like it, at least the hole for the kickstart shaft is there as well as the bolt holes for the shaft bushing bracket.
Can't see for sure if the mounting holes for the stopper plate are there though - that part is essential as the stopper plate is what causes the kickstart ratchet to disengage.
However, since all the rest is there I'm pretty sure the stopper plate mounts are too, it would seem that they used the same mould for the 650 and 750-4 cases.
Last edit: 28 Dec 2008 10:35 by OnkelB.
  • Danimal69361
  • Danimal69361's Avatar
28 Jul 2012 16:51
#539233
Hey,
I Was wondering what ever became of this project. I am interested in doing the same on my 81 kz750 that was recently given to me in pieces. I would love to know if you were successful or if i should scrap the whole idea.
  • Nebr_Rex
  • Nebr_Rex's Avatar
28 Jul 2012 18:29
#539252
B)
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Bilalgio
  • Bilalgio's Avatar
09 Jan 2021 23:39
#841466
Haha did you ever figure it out because I'd love to give it a go on my 82 and idk if you ever found an answer
  • Nessism
  • Nessism's Avatar
10 Jan 2021 05:25
#841472
Bilalgio wrote: Haha did you ever figure it out because I'd love to give it a go on my 82 and idk if you ever found an answer
Good job searching for info...only please dig deeper since there are quite a few threads on this subject detailing out how to make the mod. The forum search function isn't the best but if you use google and search "kick start on KZ750" it will turn up lots of threads here and elsewhere.
Bottom line is that it is possible as long as your bikes engine cases have the hole for the mechanism. Assuming it does then it's a fairly simple matter of splitting the cases and adding the appropriate parts and installing a clutch cover with the hole for the shaft.
The following user(s) said Thank You: papaya
