kz1000 head gasket question
  • keith1
  • keith1's Avatar Topic Author
21 Nov 2008 19:27
#248725
i am going to install jugs tommorow and when money permits purchase web cams gring #118 then send head out for freshening....the guy i got my jugs and mtc pistons from said he preferred copper and sent me a cometic copper 72 mm head gasket and said to rtv groove...as far as i can gather from reading, this might not be the way to go...i would appreciate input as i dont want to tear this apart or have leaks once it s together...this is a 1075 kit with 10.5 to 1 comp and head gasket will be a weak link if it aint right..do i go with
A-cometic one pc fiber and rtv
B-try to find 2pc 72 mm and use o ring for middle
C-use what i have
any and all input is appreciated as always.....thanks....keith
  • PLUMMEN
  • PLUMMEN's Avatar
Re: kz1000 head gasket question
21 Nov 2008 19:31
#248729
just say no unless your cylinders are o ringed it will leak like a sieve inmy experiance.B)
  • keith1
21 Nov 2008 19:35
#248730
this is what i have heard and read.....hence the inquiry....thanks
  • PLUMMEN
  • PLUMMEN's Avatar
21 Nov 2008 19:38
#248734
no problem ;)
  • keith1
21 Nov 2008 19:59
#248743
any suggestions?
  • racer54
  • racer54's Avatar
21 Nov 2008 20:10
#248747
If you can find one (and I don't know if they make one) go with the 2 pc. and center o-ring. Then go with the 1 pc. Do Not use the copper unless you have the cylinder o-ringed. It will leak, I know some use the dopper without the o-rings in the cylinder, but they just don't seal good without them. The o-rings mash into the soft copper to make the seal. Plummen is right! Again!
  • donthekawguy
  • donthekawguy's Avatar
22 Nov 2008 00:21
#248763
I think APE sells the two piece 1075 gaskets.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • stever
  • stever's Avatar
22 Nov 2008 11:28
#248812
Wiseco one piece fibre gasket, fill the slot for the o ring with sealant.
Copper needs grooves and wire to seal.
  • Exitpupil
  • Exitpupil's Avatar
22 Nov 2008 13:17
#248816
Use the Wiseco one piece gasket. Be sure to modify the dampner blocks as shown in this link. Don't ask me how I know!
www.redlinecycle.com/Blocks.html
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
  • PLUMMEN
  • PLUMMEN's Avatar
22 Nov 2008 14:17
#248826
after close to 30 years ne learns things often the hard expensive way!:laugh:
  • keith1
22 Nov 2008 14:37
#248828
good tip....thanks
  • timebomb33
  • timebomb33's Avatar
22 Nov 2008 19:36
#248898
some of you may laugh but i'm pretty handy with a knife so i carve my own out of wood and i cut them so they fit flush never had a problem with them.
I THINK MY POWERBAND BROKE
