  • Page:
  • 1
  • 2
First ride Z1R 03 May 2015 16:36 #670535
  • spdygon
  • spdygon's Avatar Topic Author
  • Thank you received: 117
Well ...took the bike out to for my first ride. Put over 200 miles around trip. Trip consisted of hwy and a lot of curves in the North Georgia Mt. Handle lot better then my 79kz1000 but felt the need for rear arm bearings.
Also the tank is small as I only got 85 miles before reserve..... That is only 35 miles per gallon...used 2.5 gallons.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
First ride Z1R 03 May 2015 21:23 #670589
  • Kapahulu
  • Kapahulu's Avatar
  • Thank you received: 44
Looks great!
2strokeworld.com
The following user(s) said Thank You: saxjonz
First ride Z1R 03 May 2015 21:40 #670594
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
What do the plugs look like? Velocity stacks?
First ride Z1R 04 May 2015 11:06 #670647
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
  • Thank you received: 443
Gorgeous bike! Beautiful countryside. And if the temps are close what we had here over the weekend (upper 70's) then you had a perfect day. Changing out the rear bearings are not a big deal. Can be expensive though.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
First ride Z1R 04 May 2015 14:41 #670679
  • spdygon
Thanks guys....actual got tired of talking about it...every where we would stop I had people come up and ask questions.
Temps were around 75.
Bike came with 29mm smooth ores but bike was not running right. I'm using my 26mm with 25 pilots and 132.5 mains. Running little rich in the mid range. Did have 17.5 but would back fire at 4k to 6 k then it would clear up. Think I need 20 or 22.5. Yes velocity stacks
1974 Z1 900 project
First ride Z1R 04 May 2015 21:32 #670721
  • SWest
  • SWest's Avatar
  • 10 22 2014
132.5's are a little large for 26's.
First ride Z1R 04 May 2015 21:35 #670722
  • Kapahulu
  • Kapahulu's Avatar
20 pilots and 120 mains work on my KZ's with stock motors, pipes and pods.
2strokeworld.com
First ride Z1R 04 May 2015 21:41 #670724
  • SWest
  • SWest's Avatar
  • 10 22 2014
I had 117.5/125 mains with a 1.5 slide cut away in my VM 28's. 1015 cast wiseco's at 10.25/1. V/H 4/1 and Andrews 1X cams.
First ride Z1R 05 May 2015 00:14 #670729
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
I'm running pods with 115mains, and #20 pilots in my 26mm carbs at density altitudes of 5,000'msl to +10,000'msl.
Runs just a wee bit rich in the slower/lower throttle settings with the #20 pilots but nice at the transition to full throttle and above. Feels rich in the high country mountains, of course, but don't they all?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
First ride Z1R 05 May 2015 07:17 #670744
  • SWest
  • SWest's Avatar
  • 10 22 2014
Yeah, my old 350 Honda didn't care what elevation we were at. CV carbs. Apples and oranges.
First ride Z1R 05 May 2015 07:56 #670750
  • barney
  • barney's Avatar
  • Thank you received: 36
beautiful pic buddy and what a nice Zed1R( Canadian pronunciation)
First ride Z1R 05 May 2015 16:12 #670794
  • spdygon
All I had were the 25 pilots...I'll have to order some 20 and 22.5 pilots
120 , 125 and 130 for mains
1974 Z1 900 project
  • Page:
  • 1
  • 2
