Kosman frame bracing kits for the Z1 KZ900 KZ1000
29 Oct 2015 10:58 #696434 by Dr. Gamma
I have been slowly putting my KZ1000 Superbike back together piece by piece. People been asking about frame bracing and where to put all the bracing needed to make the big KZ to handle. The frame picture here is what most people used in AMA Superbike racing from late 1977 to about 1981. All that thin plate gusseting around the steering stem is flat useless. Just remove all of it. Tubular bracing is the only answer to strengthening up the steering stem. Now if you add oversize motor mount bolts, and ream the frame and engine cases so that all the motor mount bolts are a interference fit or press fit. The motor becomes part of the frame. All other gusseting that is not shown is really not needed to strengthen up the frame.
1986 RG500G 2 stroke terror.
29 Oct 2015 10:58 - 29 Oct 2015 11:03 #696435 by Dr. Gamma
Sorry about all the duplicates, the library in Prescott Valley just got hit by a HUGE thunder shower, then everything locked up and then went blank. Then all the duplicates popped up.
Last edit: 29 Oct 2015 11:03 by Dr. Gamma.
  • SWest
  • 10 22 2014
29 Oct 2015 11:09 #696437 by SWest
29 Oct 2015 11:12 #696438 by Dr. Gamma
YES PLEASE!!! There should be a total of six photos with the listing. It is getting real scary here in Prescott Valley. The skies have opened up again big time !!!
  • SWest
  • 10 22 2014
29 Oct 2015 11:29 #696439 by SWest
I live in the desert too. I have a large wash the goes corner to corner on my 5 acres. It can be a torrent in seconds. I'll delete your removed posts.
The following user(s) said Thank You: Zee1mark
21 Apr 2016 19:09 #722277 by Coast Steve
Replied by Coast Steve on topic Kosman frame bracing kits for the Z1 KZ900 KZ1000
Hey DR Gamma,
Do you still offer this frame stiffening kit?
Thanks,
1982 Kawasaki Eddie Lawson S1 (1136cc race replica clone.)
  • Street Fighter LTD
  • Moderator
22 Apr 2016 07:15 #722331 by Street Fighter LTD
Replied by Street Fighter LTD on topic Kosman frame bracing kits for the Z1 KZ900 KZ1000
I may be wrong , but I dont believe he was offering to make kits for sale.
22 Apr 2016 07:52 #722344 by Coast Steve
Oh thanks Dave,
I guess I just assumed they were for sale since it was in the vendor forum.
Looks like a good idea to stiffen up things though.
22 Apr 2016 09:05 #722360 by TexasKZ
Last time i looked, PMC has a bracing kit listed in their catalogue. You could contact Z1E and ask if they can order it.
22 Apr 2016 09:22 #722363 by Coast Steve
My frame is an 81 GPZ1100 though. Not sure if it's in kit form.
I thought it would save on cutting all the pieces if I can find a kit.
Don't see anything on PMC's site though.
22 Apr 2016 10:06 #722369 by pete greek1
Replied by pete greek1 on topic Kosman frame bracing kits for the Z1 KZ900 KZ1000
Coast Steve wrote: My frame is an 81 GPZ1100 though. Not sure if it's in kit form.
Try giving 531blackbanshee a P.M., he used to make them
Pete
26 Apr 2016 11:09 #723076 by I_Tig_in_piece
Replied by I_Tig_in_piece on topic Kosman frame bracing kits for the Z1 KZ900 KZ1000
After I get my 440 back together and caught up on shop and house projects, If someone provides the appropriate frame and/or, as well as their knowledge with the Z1, 9 and/or 1k, cause I havent got a clue other than the 900 has a front wheel I want :P Also help from such individual in measuring, marking, cutting and fitting, I wouldn't mind opening the shop doors on a weekend to bang some bars out for the community B) I'm no motorcycle expert by any means, but Ive been told that my mutant power is the ability to easily spot problems and fabricating problem solving?
Also, I'm not in any way trying to step on anyone's toes or gain customers, he'll chances are it may not even happen? (that is unless you wanted to turbocharge your car :P ) sooo yeah,
Cheap labor isn't skilled, skilled labor isn't cheap.
1980 KZ440a. I went green.
If you yourself are building an older bike and can see it through till you're riding it, that's proof you have patience.
