  • Page:
  • 1
ZR7 FSM 06 Nov 2023 05:08 #891356
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Moderator
  • Thank you received: 1878
I have noticed that it is quite popular to use parts from the ZR7 in the earlier bikes, with this in mind I have added a ZR7 FSM to the "Filebase" (had to upload in 2 parts as the file is too big for a single upload !!)
The following user(s) said Thank You: Nessism, riturbo, Mikaw, rangeroy, Warren3200gt, howardhb
ZR7 FSM 06 Nov 2023 05:49 #891357
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 680
Common upgrade to fix the z650 starter clutch "issue" to a more robust 7rx one.
Z1000J2 somewhat modified!
ZR7 FSM 06 Nov 2023 08:47 #891364
  • rangeroy
  • rangeroy's Avatar
  • Thank you received: 20
oil pump & pressure relief valve & clutch basket all fit earlier models, oil pump 20% more output & basket a lot younger so the rubber puck dampers are not as worn/hard.
1977 z650
  • Page:
  • 1
