Bike port 06 Mar 2024 10:42 #896045
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2649
Bike port 07 Mar 2024 06:38 #896101
  • SWest
  • 10 22 2014
Trying to get this done.
rumble.com/v4hqoz3-back-to-the-crash-bar.html
Bike port 07 Mar 2024 20:35 #896134
  • SWest
  • 10 22 2014
Bike port 08 Mar 2024 19:43 #896194
  • SWest
  • 10 22 2014
See if it will seal.
rumble.com/v4i279c-fuel-tee.html
Bike port 09 Mar 2024 08:48 #896218
  • SWest
  • 10 22 2014
I would never known for sure without testing with known good units.
rumble.com/v4i4dgr-new-dyna-3-ohm-coils.html
Bike port 09 Mar 2024 16:17 #896231
  • SWest
  • 10 22 2014
Looks like these will work.
rumble.com/v4i9i4o-new-dyna-3-ohm-coils-2.html
The following user(s) said Thank You: Rolf1976_KZ900
Bike port 09 Mar 2024 22:44 #896237
  • SWest
  • 10 22 2014
They're looking good.
rumble.com/v4iaiq3-plug-check-3-8-24.html
Bike port 10 Mar 2024 01:47 #896241
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
  • Thank you received: 138
Oboy glad to see you finally has sorted out that ignition mess lots of testing ! I have a dyna s timingplate installed that i suspect is cheap replica and made one of my coil melt.
I have bought one set of new coils from Z enterprices  that i will try install when i get the engine back in the bike. I also have bought a boyer brasden ignition kit with coils ,but i can not install that before i have done a brake in on the engine i think.It says on the instalation manual that the engine has to be warmed up first then run at 5000rpm and use a strobelight .Not want i want when doing a brake in.
Bike port 10 Mar 2024 10:01 #896253
  • SWest
  • 10 22 2014
I suspect the coils have been going for some time and leaving the key on just made them worse. The Dyna S may still be good and I'll be checking that next. The Dyna is a power hog and on these bikes there's not a lot of power to spare. I want the Rick's rotor that provides 55% more power then I can run all the goodies I want.
At least Dyna is still making their items in the USA and they respond directly.
Technical Support
Toll Free: 800-928-3962
Bike port 11 Mar 2024 06:37 #896280
  • SWest
  • 10 22 2014
Idles smoother and advances as it should.
rumble.com/v4ij8z0-dyna-rotor.html
Bike port 11 Mar 2024 10:15 #896287
  • SWest
  • 10 22 2014
Hooked up the relay again.
rumble.com/v4ii5x0-coil-relay.html
Bike port 12 Mar 2024 07:04 #896315
  • SWest
  • 10 22 2014
See if there's any hope for this thing.
rumble.com/v4inayi-grinder-brushes-came.html
