Z2 750 crank (Bossie the Kaw) 12 Apr 2015 19:45 #667732
  • Thank you received: 2098
Patton wrote: Per Dave Marsden:
THE Z2 WAS IDENTICAL TO THE LARGER BIKE IN DESIGN EXCEPT FOR THE DISPLACEMENT OF JUST 746 CC AND SMALLER 26MM CARBS.
IT WAS ONLY OFFERED IN THE BROWN AND ORANGE COLOUR OPTION FOR THAT YEAR.
ENGINEER INAMURA DECIDED THAT SIMPLY REDUCING THE BORE SIZE OF THE Z1 WAS NOT GOOD ENOUGH. INSTEAD KAWASAKI CHANGED THE BORE AND THE STROKE TO 64MM X 58MM. THIS CHANGE REQUIRED A DIFFERENT CRANKSHAFT, CYLINDERS, PISTONS, PINS AND RINGS. THE REST OF THE MOTOR REMAINED THE SAME.
Dave Marsden also said:
"I HAVE LISTED BELOW THE MAIN PARTS THAT WERE DIFFERENT FROM THE 1973-1975 Z1 RANGE OF MODELS:
CYLINDER BARRELS: 11006-014 (BLACK)
PISTONS: 13001-063 STD
PISTONS: 13027-061 1.00MM OVERSIZE
PISTONS: 13029-065 0.5MM OVERSIZE
RING SET: 13008-048 STD
RING SET: 13024-051 1.00MM OVERSIZE
RING SET: 13025-050 0.5MM OVERSIZE
PISTON PIN: 13002-026
CRANKSHAFT ASSY: 13031-044
CARBURETTOR ASSY: 16001-202 26MM MIKUNI
REAR SPROCKET: 42041-132 42 TEETH
DRIVE CHAIN: 92057-025 96 LINKS
REAR SHOCK ABSORBER: 45014-089 (1973 MODEL WITH ORANGE REFLECTORS)
REAR SHOCK ABSORBER: 45014-083 (1974/75 MODELS WITH RED REFLECTORS)
EMBLEM: 56018-153 LH PANEL
EMBLEM: 56018-154 RH PANEL
SPEEDOMETER: 25001-073 KPH
SPEED WARNING LIGHT: 23016-014
SWITCH (SPEED): 25025-003
SWITCH BRACKET: 32060-012
PARTS BOOK: 99997-103-04
INTEREST IN THIS RARE MODEL IS HIGH LEADING TO A SECTION OF THE CLASSIC KAWASAKI OWNERS CLUB BEING DEVOTED TO IT. THEY EVEN HAVE THEIR OWN RESIDENT Z2 EXPERT, JOHN BROOKES."
The above was published in 1998.
Good Fortune! :)
Z2 750 crank (Bossie the Kaw) 12 Apr 2015 21:29 #667739
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2621
What's the name of the site?
Z2 750 crank (Bossie the Kaw) 13 Apr 2015 01:15 #667752
  • davido
  • davido's Avatar
  • Thank you received: 286
www.z1ownersclub.co.uk/forum/index.php
Or Dave Marsden can be got through;
www.z-power.co.uk
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: by davido.
Z2 750 crank (Bossie the Kaw) 13 Apr 2015 05:59 #667764
  • SWest
  • 10 22 2014
Thanks
Z2 750 crank (Bossie the Kaw) 13 Apr 2015 07:14 #667773
  • SWest
  • 10 22 2014
Nothing useful there. Of course the part numbers are different. The cam chain is the same as the Z1, the wrist pins are both 17 mm, The sleeve OD is the same. What I need to know is the Marking codes on the crank and rods. I will need them anyway if I decide to sell the crank.
Z2 750 crank (Bossie the Kaw) 13 Apr 2015 10:49 #667786
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
  • Thank you received: 62
An old friend of mine's Dad has a beautiful, (original) 1967 SS/RS Camaro that he bought brand new...He gets absolutely FURIOUS when some "know it all" at a car show tries to tell him what he's got.... under the hood or anywhere else on the car...the "takeaway" from this (for me) is that IT IS HIS VEHICLE, HE OUGHTTA KNOW WTF HE HAS...Cheese on rice, let this one GO already! LOL!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
Z2 750 crank (Bossie the Kaw) 13 Apr 2015 11:50 #667791
  • SWest
  • 10 22 2014
Hey Grumpy, haven't talked to you in a while. I'm taking the opportunity to document my build. I didn't get all the pics I should have. The crank is one of them. I was actually done a favor. It may be the 750 crank is a waste and I'm loosing ponies for it. I didn't realize just how valuable it is. I'm looking at it as a experiment. 903 cranks are easy to get. I had one but one of these low lives cost me it by burning down my shop.
"When it rains lemons, make lemonade. :woohoo:
The following user(s) said Thank You: Grumpy Ole Artist
Z2 750 crank (Bossie the Kaw) 14 Apr 2015 06:23 #667884
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
no dog in this fight .
but here is a cc calculator
www.everything2stroke.com/content/36-Eng...placement-Calculator
wiseco list a 70 mm bore as standard for 1015cc's
and we have established z2's have a 58 mm stroke
4 cylinders
which gives us 893 cc's
rod length doesn't figure in to an engines size.
a formula using bore and stroke determines engine size.
hth,
Last edit: by 531blackbanshee.
Z2 750 crank (Bossie the Kaw) 14 Apr 2015 06:24 #667885
  • MDZ1rider
  • MDZ1rider's Avatar
  • Thank you received: 118
swest wrote: What I need to know is the Marking codes on the crank and rods. I will need them anyway if I decide to sell the crank.
Ask John Brookes (This email address is being protected from spambots. You need JavaScript enabled to view it.). If anyone knows, he will. Here's his Z2 site.
www.freewebs.com/750rs/
Z2 750 crank (Bossie the Kaw) 14 Apr 2015 06:48 #667888
  • SWest
  • 10 22 2014
Being the stock 1015 pistons are only 2 mm lower on the deck height and the 10.25/1 were even, I suspect the crank throws are different and the wrist pins are as well. There's only one way to find out for sure. I found a stock 903 piston and will compare it to the 10.25's but that won't tell us anything about the 750's. I'm going to send john a e-mail to see what he can provide.
Z2 750 crank (Bossie the Kaw) 14 Apr 2015 06:53 #667889
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
  • Thank you received: 443
531blackbanshee wrote: no dog in this fight .
4 cylinders
hth,
Leon, yes I used a bore of 69.4 mm which I got from www.motorcyclespecs.co.za when calculating the cylinder volume; (pi)*(3.47)sq*(5.8) then times 4 (four cylinders) = 877.60 cc . That is how I ended up with the 877.60 cc. If would have used a 70 mm bore the formula comes up with 893 cc. For a K1000, using a 70mm bore with a 66mm stroke the formula comes up with 1015. So not sure why that website states 69.4 mm for the bore on a KZ1000.
Leaving that aside, yes the throw of the crank is what is going to determine the stroke (height of the cylinder). My question is though, given the stroke is shorter, does that mean longer rods would need to be used in order to get the compression back? Are the 750's rods longer than the 900 rods in order to compensate for the 8 mm difference in throw? Thereby achieving the same deck height? Just curious on how Kawasaki did it.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: by KZJOE900.
Z2 750 crank (Bossie the Kaw) 14 Apr 2015 07:13 #667893
  • 531blackbanshee
  • Vendor
can't speak to z2 rod length or piston pin height.
here is the formula i have used for years to figure cc's
bore x bore x 3.14 x stroke = ____
divided X 4000 = cc's for one cylinder
so then you multiply that times the # of cylinders
hth,
