Z2 750 crank (Bossie the Kaw) 30 Nov 2021 22:09 #858505
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2635
Z2 750 crank (Bossie the Kaw) 02 Dec 2021 16:06 #858558
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
Today was it...last ride for the year.
Glad I had the head work done.
Looking forward to Spring!
1982 KZ1100-A2
Z2 750 crank (Bossie the Kaw) 02 Dec 2021 16:20 #858559
  • SWest
  • 10 22 2014
No Indian summer on the horizon?
Z2 750 crank (Bossie the Kaw) 03 Dec 2021 18:40 #858582
  • daveo
  • daveo's Avatar
  • Premium Member
Nope.
39 degree high tomorrow, with 5% chance of precipitation.  That is the warmest day forecast through next week.
Cool crisp air...hmmm.  I have riding gear for that!
1982 KZ1100-A2
Last edit: by daveo.
Z2 750 crank (Bossie the Kaw) 07 Dec 2021 22:32 #858773
  • SWest
  • 10 22 2014
It's going to be real soon.
Z2 750 crank (Bossie the Kaw) 08 Dec 2021 12:28 #858825
  • Mikaw
  • Mikaw's Avatar
  • Away
  • Thank you received: 1873
Steve, did you bore a 1000 block, and you want to use the 900 exhaust collars. Will this help?
www.z-power.co.uk/exhaust-stud-68mm
Z2 750 crank (Bossie the Kaw) 08 Dec 2021 12:51 #858833
  • SWest
  • 10 22 2014
I had APE bore the block to match the 1075 pistons and am using that junk 1000 head I brought back to life.   The m6 Helicoils expanded to fit the M6 studs. I have the M8 to M6 inserts to use this time. The one I installed in the case for the sprocket cover is still going strong.   Ready the do the switchover tomorrow then RIDE THE PISS OUT OF IT AGAIN.
Last edit: by SWest. Reason: sp
Z2 750 crank (Bossie the Kaw) 10 Dec 2021 21:46 #858937
  • SWest
  • 10 22 2014
I've decided to wait until after the 1st.
Z2 750 crank (Bossie the Kaw) 11 Dec 2021 06:03 #858946
  • daveo
  • daveo's Avatar
  • Premium Member
With Bossie looking so good, you may as well keep riding it out!
1982 KZ1100-A2
Z2 750 crank (Bossie the Kaw) 20 Dec 2021 16:16 #859391
  • SWest
  • 10 22 2014
This was last month.
Z2 750 crank (Bossie the Kaw) 15 Jan 2022 18:17 #860575
  • SWest
  • 10 22 2014
Finally getting down to it.
Last edit: by SWest. Reason: add clip
Z2 750 crank (Bossie the Kaw) 16 Jan 2022 07:32 #860581
  • SWest
  • 10 22 2014
Cam bearings are looking good.
