Z2 750 crank (Bossie the Kaw) 06 May 2021 07:26 #848084
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2645
Have enough to do the R side too.
Z2 750 crank (Bossie the Kaw) 06 May 2021 14:58 #848101
  • SWest
  • 10 22 2014
Picking up the $75 74 Z1 front end was a good move. Nobody wanted it because it looked so bad.
Z2 750 crank (Bossie the Kaw) 07 May 2021 07:19 #848149
  • SWest
  • 10 22 2014
Sam still had that 74 Z1 front end after 2-3 years so I guess it was meant to be.
Z2 750 crank (Bossie the Kaw) 14 May 2021 19:12 #848454
  • SWest
  • 10 22 2014
Turned out to be one FK'ED UP DAY.
Z2 750 crank (Bossie the Kaw) 15 May 2021 09:13 #848484
  • SWest
  • 10 22 2014
Not going to be easy.
Z2 750 crank (Bossie the Kaw) 15 May 2021 09:40 #848485
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
Steve, both of my 33’s have brass floats. You sure those are ok to run.
EDIT, they measure approximately 30.28mm
EDIT,EDIT; please don’t attempt this at home. Smoking while working around gasoline
Last edit: by Mikaw.
Z2 750 crank (Bossie the Kaw) 15 May 2021 11:50 #848492
  • SWest
  • 10 22 2014
They will work but there's a very small window in which to do it as you can see. The brass floats can crack and fill with gas. Common issue with all brass floats. I'll be ordering a set soon.
As for smoking around gas, I grew up around people that did it with no accidents. Just need good ventilation and being careful. I'm not suggesting others do it. It CAN BE DANGEROUS.
Z2 750 crank (Bossie the Kaw) 15 May 2021 17:21 #848503
  • SWest
  • 10 22 2014
Taking longer than expected.
Z2 750 crank (Bossie the Kaw) 16 May 2021 06:26 #848525
  • SWest
  • 10 22 2014
Hard to get them right with these floats.
Z2 750 crank (Bossie the Kaw) 17 May 2021 07:52 #848596
  • SWest
  • 10 22 2014
They changed the rubber compounds on radiator hose?
Z2 750 crank (Bossie the Kaw) 17 May 2021 12:32 #848615
  • SWest
  • 10 22 2014
Might have to adjust 1&4 on the bike.
Z2 750 crank (Bossie the Kaw) 18 May 2021 08:21 #848685
  • SWest
  • 10 22 2014
Had to adjust #1 on the bike. Not so wary bad.
