- Lorcan
- Speed Loony
29 Sep 2013 15:31
Strapping the front is much better than sliding the forks through the yokes as it also stiffens the fork and means the front wheel won't move any further than it would as standard, so no clearance issues will come from it.
You can also vary the strap to suit different tracks and the grip available - strap down hard for a grippy track and less so for marginal tracks.
Here's my 750 strapped down to about 1.5" of movement (4" standard).
I ran 1.56 sixty foots at 60" (+2" from standard) wheelbase with this setup.
If you rake the front you'll most likely find that it hits the bars harder but every pound of weight ON the bars is a pound OFF the rear tyre which is where you want it to be. Keep the weight towards the front of the bike and adjust the wheelbase is the modern way.
Here's my 760cc bike with 4" welded in the arm from another bike - a KLR650! You can see the welds in this pic and the support plate underneath which doubled as a wheelie bar mount.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
The following user(s) said Thank You: old-school
- zukdave
29 Sep 2013 20:09
With the GPz arm I'm 2 1/2" over stock.
I have a strap but it still will hit the cooler.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- geerbangr
30 Sep 2013 02:02
Wth is the guy doing behind that bike with the hockey stick and a brick ? :S
1978 KZ 1000
I go by Jason
I go by Jason
- Lorcan
- Speed Loony
30 Sep 2013 03:04zukdave wrote: With the GPz arm I'm 2 1/2" over stock.
So move the cooler
760cc - 8.69@162mph
- Lorcan
- Speed Loony
30 Sep 2013 03:07geerbangr wrote: Wth is the guy doing behind that bike with the hockey stick and a brick ? :S
I knew someone would ask that... :lol:
This was at a sprint event back in the 90s. Back then once you had staged you could, if you wanted to cheat the clocks, roll back a little before launching without triggering a red light in order to get a run up at the lights. So they had a guy with a wooden chock to stop you. They still do this at certain historic events like Brighton Speed Trials.
760cc - 8.69@162mph
- geerbangr
01 Oct 2013 00:43
Alright Lorcan that makes sense. I looked at that pic,scratched my head and went :blink: :ohmy:
1978 KZ 1000
I go by Jason
I go by Jason
- DoctoRot
07 Oct 2013 16:59Please Log in or Create an account to join the conversation.
- Puffin
08 Oct 2013 07:03Very cool looking Racer Doc, do you have anymore photos/info on it. Chassis looks very much like a Zuk
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
- DoctoRot
08 Oct 2013 17:33
thats all i got but it appears to be a morawaki engineering bike or a clone.
- Dr. Gamma
08 Oct 2013 17:41
1986 RG500G 2 stroke terror.
- byars
09 Oct 2013 13:19
Z1 Car tire conversion dragbike (SAM WILLS)
81 Gpz (84 1170 motor)
- byars
09 Oct 2013 13:21
