  • Page:
  • 1
Lost gas cap key 10 Dec 2023 17:46 #892566
  • KZNewbie76
  • KZNewbie76's Avatar Topic Author
  • Thank you received: 2
What do I do in his situation? Thanks
Lost gas cap key 10 Dec 2023 18:32 #892567
  • JR
  • JR's Avatar
  • Thank you received: 435
Use any old key or piece of metal that will fit in the slot. Most if not all the kz gas caps are not "keyed" per se. Keys for my shed pad locks, mailbox front door work just fine. Small flat blade screwdriver or similar also.
The following user(s) said Thank You: Street Fighter LTD, howardhb, KZNewbie76
Lost gas cap key 10 Dec 2023 19:09 #892570
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1864
Yep
The following user(s) said Thank You: KZNewbie76
Lost gas cap key 11 Dec 2023 13:15 #892611
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
  • Thank you received: 303
Gas caps were keyed from 1983 on.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: JR, Street Fighter LTD
Lost gas cap key 11 Dec 2023 14:23 #892615
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
  • Thank you received: 223
You can remove the wafers inside the cylinder so that any key that fits inside will turn it. Or you can move the wafers around so that a couple of them will work with your ignition key.
Ive done it on gas caps as well as helmet locks.
The following user(s) said Thank You: Mcdroid, Street Fighter LTD, howardhb
Lost gas cap key 31 Dec 2023 10:07 #893329
  • KZNewbie76
Anything that I put in there it just kept spinning I am at my wits and and I cannot figure out how to get this thing open. I'm about to put a screwdriver in the top of it and pound it in with a hammer in about 5 minutes
Lost gas cap key 31 Dec 2023 10:45 #893330
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 657
Tap the hinge pin out and remove the whole cap. Then you can dismantle the lock and sort it out.
Z1000J2 somewhat modified!
Lost gas cap key 31 Dec 2023 15:44 #893346
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Early non tumbler key holes work that way on the gas cap.
The top half of the keyhole just spins.
You need to be able to reach in a 1/4 inch to the second/lower part of the keyhole, and turn that.
The Ignition key should do it, if it slides in.
Otherwise spray some lubricant in it to free up stuck parts.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: by rstnick.
  • Page:
  • 1
