  • Page:
  • 1
KZ650 Never Ending Project 27 Jul 2023 13:40 #887653
  • KZED650
  • KZED650's Avatar Topic Author
  • Thank you received: 2
Attachment not found
I bought this bike as a basket case in 2004.
I parked it 6 years ago when my first was born. Broke it out this season. Wow it needed a lot of work.
Did carbs, intake boots, carb holders and exhaust gaskets to hunt down a backfire on deceleration. It was infact the result of the carb holders being cracked and a carb body was loose from the bank.
Cam end plugs and valve cover gasket.
​​gasket.
Dual disk conversion and front brake job, bleed etc.
Clutch
All new tubes and hoses
Cleaned fuel tank
New steering bearings
Detail and polish all aluminum
Front wheel bearings
Forks flush and fresh oil.  Went 15W
Air filter
Its going into the shop for chain and sprockets. Currently 13 / 38 going to bump to 40 on rear and fresh rubber. I did all the other work myself.
Not really a lot of money, but quite a bit of time.
Need recomendations on dual disk master cylinder, brake lines and chain type...O or X.
KZ650 Never Ending Project 27 Jul 2023 16:01 #887658
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
X ring chain is better than O ring, as a general rule.
5/8" bore master.
I like to make my own brake lines from earl's parts.  My build thread has a tutorial.
KZ650 Never Ending Project 27 Jul 2023 18:30 #887666
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 309
We use Apex Brakes for all of our brake lines. He has the specs for most bikes. Over half of our bikes have Apex lines. Custom length lines are not a problem, in our case its usually the master cylinder to splitter is shorter due to a bar change.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
KZ650 Never Ending Project 28 Jul 2023 13:16 #887691
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 266
My brake lines are all Goodridge from Z1E. I don't mind the extra maint required to run a NON-Oring chain
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
  • Page:
  • 1
