1973 Z1 Maui 27 Jun 2022 08:18 #869420
  • MauiZ1
  • MauiZ1's Avatar Topic Author
  • Thank you received: 19
Still waiting for my cams to come back.
I think the tank and body work are done, have to go get it all soon.
1973 Z1 Maui 27 Jun 2022 08:27 #869422
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1919
Exciting times
1973 Z1 Maui 27 Jun 2022 13:47 #869435
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1043
I'm sure you've checked those bearings a few times.
1973 Z1 Maui 06 Jul 2022 19:38 #869988
  • MauiZ1
Just learned my cams are finally coming back after polishing. Maybe I’ll finally get this going again. The tank and body stuff are done, I just need to fly over and pick them up. I sure hope this all works out. Now at least I have a pretty good idea of what really was my problem. Learning curve!
1973 Z1 Maui 07 Jul 2022 05:05 #869995
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1884
Good luck.
1973 Z1 Maui 18 Jul 2022 14:37 #870570
  • MauiZ1
This may be the end of my frustrating road with this project.
After the last miserable failure of cam bearings I took it all apart looking for a cause, I even thought I found one.
I looked at oil passages, measured the oil pump, made sure the o ring between the engine case halves was perfect, blew out all the passages, assembled the cams with no valve gear to make sure they spun well, made sure the oil pressure switch had the bleed hole.
put it together yesterday and started it. I cranked it until the oil light went out, about 30 seconds. Started it up, ran excellent for a minute or so and stopped. Cam bearings again.
so now I’m back to trying to find out what is really wrong with this or maybe I should just end my misery and be done with it.
I’ve missed something that must not be very obvious.
I have one more set of cams to use and I believe I can clean this set up.
very, very frustrating, I’m not accustomed to this type of failure.
1973 Z1 Maui 18 Jul 2022 14:52 #870572
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Is it the same journal that have failed again ? And has the bearing turned as before ?
Last edit: by Wookie58.
1973 Z1 Maui 18 Jul 2022 14:55 #870573
  • katit
  • katit's Avatar
  • Thank you received: 48
Good Q. Also, is that the same head? You may need to make sure that journal oil supply hole is not plugged
1973 Z1 Maui 18 Jul 2022 16:47 #870580
  • MauiZ1
Same head
they didn’t turn
I’m back to oil delivery because several seized up. I just can’t see where oil delivery would be an issue, unless I’m blind to something.
1973 Z1 Maui 18 Jul 2022 16:51 #870581
  • hardrockminer
Well that's depressing!  Whatever it is....it's something no one has experience with.  Small consolation I know.  Did you get oil up into the head?
1973 Z1 Maui 18 Jul 2022 23:01 #870598
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Same head
they didn’t turn
Did you drill the cylinder block as recommended by Zed1015 to clearance the heavy duty studs ?
1973 Z1 Maui 19 Jul 2022 00:48 #870602
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
Non matching cam caps ?
