  • Page:
  • 1
  • 2
74 Z1A 06 Jul 2021 11:40 #851385
  • hx35w
  • hx35w's Avatar Topic Author
  • Thank you received: 5
In the back of my garage I have had a Z1 engine sitting on a engine stand for about 25 years now. one day I got to looking at it to see what it would take to get it running. The top end needed to be completely reworked. Two new valves, valve guides, new pistons and rings. The bottom end gears and shifter forks was in good condition. I did replace oil seals and bearings while I was in it. I needed other tings like friction plates, Ignition system, carbs and a couple of side covers. After the engine was said and done with I thought it would be cool to find a frame! (Can you guys see where this is going?) One and a half  years later I'm thinking I should of had someone around to kick my BUTT for starting this project. I have had to buy every nut , bolt and components to build this thing, including spokes. I'm on the down hill side of this project now. the only thing is paint work.  Until the wife gives me some more money, I'm Kind of in a holding pattern. It will look good next to my 73 Z1 and my ELR
Last edit: by Street Fighter LTD.
74 Z1A 06 Jul 2021 11:49 #851388
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1866
Looking really nice. Keep the faith.
EDIT, Moreover keep momma happy. Ask for St. Nick to help
Last edit: by Mikaw.
74 Z1A 06 Jul 2021 13:13 #851396
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1036
For starting with just an engine you're doing pretty good!  Are those carbs black?
74 Z1A 06 Jul 2021 13:20 #851397
  • krazee1
  • krazee1's Avatar
  • Thank you received: 197
Looking Good!  You're ahead of me,  I have a rolling chassis and an unassembled motor at this point.  I've lost some of my interest in the project because the PO has not been helpful in getting a duplicate title for me. In NE you can obtain a Bonded Title,  but that appears to be a real PITA.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
74 Z1A 06 Jul 2021 14:31 #851406
  • hx35w
I am going for a bonded title as well. My 74 is considered a Reassembled Vehicle
74 Z1A 07 Jul 2021 05:44 #851444
  • hx35w
The carb body's are black. It's a baked on coating that is impervious to petroleum based or chemicals.
74 Z1A 14 Feb 2022 18:38 #862369
  • hx35w
buff the paint and get rid of a gremlin or two then it's time to play!!
Last edit: by hx35w. Reason: not good
74 Z1A 14 Feb 2022 18:58 #862372
  • hx35w
74 Z1A 14 Feb 2022 19:00 #862373
  • hx35w
The following user(s) said Thank You: BCScott
74 Z1A 15 Feb 2022 06:14 #862398
  • Wheelhop
  • Wheelhop's Avatar
  • Thank you received: 294
Nice work, she turned out great!  What type of exhaust / Header is that?
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
74 Z1A 15 Feb 2022 07:08 #862399
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1906
DELKEVIC
delkevic.com/complete-systems/kawasaki/1973-models/
74 Z1A 15 Feb 2022 18:19 #862440
  • hx35w
It is a Delkevic, polished stainless. great finish and center stand friendly. I will say when I initially installed it the bottom of the header was a lot closer to the ground than I liked. I fixed that problem by indexing the muffler about 10 degrees CCW and fabricating my own mount and center stand stop. There mounting hardware is worthless. By making the modifications I was able to get 1 1/2 to 2" more ground clearance.
  • Page:
  • 1
  • 2
