Katit's 1978 KZ650 project 16 Mar 2021 10:51 #845008
  • katit
  • katit's Avatar Topic Author
  • Thank you received: 48
Nessism wrote: www.enginehones.com/212240sc.html
Used cylinders & pistons are much cheaper than going the bore & new pistons route. Success depends on finding good used parts though of course.
Thank you! Order placed. Buying a ton in last couple days, now to wait for stuff to come in.
Now I need to work on prepping all parts for paint. Even though cerakote does not need to be baked- they recommend bake parts before to make sure any grease is burnt. Going to get used oven from CL for that. Later I may convert it into DIY bigger oven cabinet.
After engine cases clean and painted - I will start working on checking all parts per FSM
Katit's 1978 KZ650 project 16 Mar 2021 20:06 #845037
  • katit
Started cleaning up this head. And dang.. Whats wrong with those people?
2 of the intake threads messed up in a bad way. No easy timesert here. Any suggestions on repair?
And.. What do I do with those emissions holes? I want to use my cover
And, speaking of those 750 heads. What else will I need if I find one? Do I need different carb? Will 650 cylinders work? Basically, if I shop (if) for 650/750 head, what else will I need?
At least with this one I know with repairs I have most parts
Katit's 1978 KZ650 project 17 Mar 2021 08:17 #845067
  • katit
At this point I feel like I need to use machine shop for head work. Any recommendation on good one in US? I am in St Louis, don't know of any local shops but I am OK with shipping if they are good.
Katit's 1978 KZ650 project 18 Mar 2021 01:38 #845129
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Man that sucks. You think they would have stopped after the first one. APE is a good resource but you will have to ship. They specialize in repairing damaged heads. but a used head might be a cheaper route.
Last edit: by DoctoRot.
Katit's 1978 KZ650 project 18 Mar 2021 07:47 #845138
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2089
Some people should not be allowed to own tools.
Katit's 1978 KZ650 project 18 Mar 2021 11:39 #845159
  • katit
Emailed APE, will see how it goes. Checked eBay for used stuff - it's all lottery. they all $100 give or take and all "used in great condition". Mine was so dirty I didn't even see those studs until cleaned and blasted those spots. So, thinking how fragile those thread are - I can see how pretty much "any" 40 year old motor will have similar issue(s)
There is one NOS head on eBay for $800 haha.
Katit's 1978 KZ650 project 18 Mar 2021 12:09 #845160
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1042
Have you tried chasing the threads with a tap?  Just a guess but I think it would be M6 by 1.25.
Katit's 1978 KZ650 project 18 Mar 2021 12:13 #845161
  • katit
Look at pictures. Threads IS there. They just not in correct spot, about 3/16 off center, putting intake manifolds in a bind. Someone broke bolts but wasn't able to correctly extract broken bolts making it even worse.
I get it, it was PITA with head/engine on a bike, but...
Katit's 1978 KZ650 project 18 Mar 2021 12:50 #845163
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1920
If you pay the shipping you can get a 650 head for free. All threats in good condition, no broken fins. Only cam bearing cap #2 and 4 are missing.
It was a cheap 50 Euro ebay offer i bought only for the shim under buckets i need. Both cams also available.
Katit's 1978 KZ650 project 18 Mar 2021 12:56 #845164
  • katit
That "only" is a problem. They machine caps with head at a factory, you can't just replace cap as they go mated with a head. This is main reason I am not using my original head (see page 1) as someone replaced cap #8
And how do you know everything else is good? Valves, guides etc? If it was just for threads I could probably figure out something myself or fix it quickly locally. I am guessing surfacing might be needed and valve lapping and potentially guides.
Katit's 1978 KZ650 project 19 Mar 2021 08:29 #845204
  • katit
Yesterday I put some more time working on head. Took valves out, inspected a little. There is corrosion on guides and valves. Not working surfaces but still.
Checked manual, removing/replacing guides if needed is not a problem , I got all the tools.
If I get Neway cutters - I can do valve seats no problem.
So, the only thing remaining - check for warpage and fix threads. Got helicoils on order, will try to repair.
Sounds like with my own tooling I should be able to get most of it figured out.
Any pointers on exact Neway kit/set? I know I need 45/30/60 cutters.
Any pointers / info on how to block smog ports? I see it's just a hole going to exhaust valve. How should it be plugged?
Katit's 1978 KZ650 project 19 Mar 2021 10:08 #845215
  • DoctoRot
  • DoctoRot's Avatar
I blocked the emission holes by tapping them (from the valve cover side) and then screwing in a set screw with some red threadlocker.
If you have a good head that is missing a cam cap try pulling the valve train and bolting in a cam. try several different cam caps from the other head you have. If it turns over easily by hand I wouldn't hesitate to run it.
