Katit's 1978 KZ650 project 01 May 2022 14:01 #866482
  • Wookie58
  • Wookie58's Avatar
  • Online
  • Moderator
  • Thank you received: 1935
I can't help you with this one, I'm no painter. However these things in isolation often look better when it's all back together
Katit's 1978 KZ650 project 01 May 2022 15:44 #866493
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
 I don't like wearing respirator either.
You probably won't get much exposure doing those parts but, My trade is in Industrial  coatings , I know a lot of "old school" spray painters" I know of two that have died from the effects of being lax with respirators and another that's going blind because of paint fume exposure. I've worn respirators all my life, I don't like wearing them either, but I like breathing without an oxygen tank.... Just saying
Katit's 1978 KZ650 project 01 May 2022 17:31 #866503
  • katit
  • katit's Avatar Topic Author
  • Thank you received: 48
I do understand issue. Probably not a big deal when outside and windy but for urethane I did wear it.
anyways, it’s done now. Not horrible by any means but could be better for sure. Once all together it will be fine
Katit's 1978 KZ650 project 01 May 2022 19:03 #866505
  • katit
It's not 10ft job, more like 6ft :) Question to painters. If I need to touch up places (not visible, for protection). Can I just use paint out of can (no hardener) ?
Katit's 1978 KZ650 project 01 May 2022 20:42 #866511
  • 750 R1
  • 750 R1's Avatar
Your question isn't entirely clear ?  If you used a paint with hardener, and you use that paint again,  you must add hardener, if you mean can you touch up from a spray can, then yes, but it probably won't match. If I was going to touch anything up further down the track, I'd use the same paint you've already used and lightly sand and clean the area you wish to touch up...
If you are going to use a spray can still lightly sand and clean , then spray. The light sanding will allow the touch up paint to adhere better..
Katit's 1978 KZ650 project 02 May 2022 08:35 #866533
  • katit
No, I need to touch up now. Those places cosmetically not important(not visible), just where I didn't get with a gun. I can touch them up with a brush, more for protection.
Since I need very tiny amt of paint it would be hard to mix, don't need reducer there for sure, but wondered if it going to dry without hardener.
Katit's 1978 KZ650 project 02 May 2022 11:11 #866543
  • calum
  • calum's Avatar
I have a load of eye droppers that I nicked from the chemistry teacher at school. They're pretty good for mixing small amounts of paint and hardener.
The following user(s) said Thank You: katit
Katit's 1978 KZ650 project 02 May 2022 14:34 #866557
  • 750 R1
  • 750 R1's Avatar
As I said, if the paint needs hardener, then use hardener, it won't cure properly without it... If you're going to brush it on you'll still need to mix about 100mm, about a fifth of a pint,  better to have a touch too much than not enough..
When painting frames, you generally start painting the hard to get bits first...
Katit's 1978 KZ650 project 02 May 2022 15:32 #866562
  • katit
So I did. I even painted upside down, starting from hard to reach areas. Then flipped and painted rest. But somehow there is places where I simply couldn't get in with a gun. Or if I did - I would put paint all around and get runs.
Katit's 1978 KZ650 project 03 May 2022 07:45 #866585
  • katit
Even "unbuilding" wheel takes time. Started with mocking up what I have. Standard setup on a picture. I am going to use dual-brake setup from 650C. For bottoms, disks, calipers, etc need to be mocked on a spoked wheel. Hope to check fit today before continuing.
Katit's 1978 KZ650 project 03 May 2022 15:19 #866598
  • 750 R1
  • 750 R1's Avatar
Yes, its fiddly alright, I usually suspend the frame , with a length of wire, off a rafter in the shed, so I can spin it around easily to get the hard to get to spots.
I suppose another way would be to brush paint the hard to get spots first , then spray everything else, I've never needed a brush though, but I usually use spray cans, not a spray gun...
Last edit: by 750 R1.
Katit's 1978 KZ650 project 04 May 2022 07:30 #866606
  • katit
CSR fork bottoms with dual brakes do fit and spoked hub looks to be working OK. Going to proceed with this setup
