I try collect evertyting i Do with the bike on these page.
Gas Tank:
I have now removed corrosion in the gas tank with phosphoric acid, the result was good.
But the paint outside the tank dident like gas over time... so I will do some temp. paiting on the tank so I can use ut for the summer seasion,
and do a proper paint in the winter, want to paint the whole bike then...
See attached pictures.
Compression test
As you can see above have I done compression test, with cheap ebay tools... so I don`t trust the numbers.
But the bike was running fin on idle so I hope it`s good enough.... ?
Carbs:
I have clean the carbs and replaced all o-rings, gasket, mix screw and screws.
Valves clearance:
I have measured the valve clearnes and order new shims.
I also order new gasket for the valve cover.
Summary:
When I bought the bike was running fine on idle, but when you gave throttle is was not good.
So I have started with clean carbs and adjust the valvue, so lets hope it will solve the problem, and I will be able to run the bike fin for the summer .... ??
The only thing I don`t have checked is the timing on ignition, and I don`t have planned todo it.
