That @#$%^&!!! KZ650! 18 Nov 2016 07:03 #748223
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
When riding at high speeds there is a vortex created where the pods are. That starves the carbs of air. (rich) Same with winds. I had duel pods and they looked cool. Miller talked me into putting my airbox back on. In the desert we have winds a lot and long stretches of roads thus high speeds. :evil:
That @#$%^&!!! KZ650! 18 Nov 2016 13:09 #748243
  • seanof30306
  • seanof30306's Avatar Topic Author
Would you get fluttering when you were going down the road?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
That @#$%^&!!! KZ650! 18 Nov 2016 13:16 #748244
  • SWest
  • SWest's Avatar
  • 10 22 2014
It would act like it was running out of fuel.
That @#$%^&!!! KZ650! 18 Nov 2016 13:24 #748245
  • seanof30306
Mine was like that slight fluttering in your video at :38 and :46
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
That @#$%^&!!! KZ650! 18 Nov 2016 14:38 #748251
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
If there is a strong side wind just right I get that effect not often but some times .... like its running out of fuel.... damn pods and when I had em open for years too .... but I still love em. :P
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
That @#$%^&!!! KZ650! 18 Nov 2016 17:04 #748267
  • tfh903
  • tfh903's Avatar
  • Thank you received: 8
Had the same issue on my Z1, the fix was routing the carb bowl vent lines under the seat behind the side cover ending them in a short pvc tube so they did not get any wind effect. I think the wind was putting too much pressure in the bowls and not allowing the fuel into the bowls. What ever after several years now, have not had the issue any more. 29 smooth bores and pods.
That @#$%^&!!! KZ650! 18 Nov 2016 19:32 #748276
  • seanof30306
tfh903 wrote: Had the same issue on my Z1, the fix was routing the carb bowl vent lines under the seat behind the side cover ending them in a short pvc tube so they did not get any wind effect. I think the wind was putting too much pressure in the bowls and not allowing the fuel into the bowls. What ever after several years now, have not had the issue any more. 29 smooth bores and pods.
Any chance you've got some pics?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
That @#$%^&!!! KZ650! 19 Nov 2016 12:16 #748364
  • tfh903
  • tfh903's Avatar
My Bad.. I used a heater hose on the Z1 and a water hose on the LTD to put the vent lines in. To trouble shoot problem - when experiencing problem stop and remove vent lines from carb and retest over same road area at same direction to get same wind action.
I found that by going to store on way there the bike acted like it was running out of fuel, on the way back it was ok. removed lines at carbs, and made 2nd trip to store and back no problems. Put the lines back on and made third trip with same results as first trip. I then put longer lines on and routed them back under seat and behind the side cover and into a hollow tube (ie: heater hose/water hose). Retested and have since left them alone for years now. Did same mod to the LTD. I believe that the wind was pressurizing the float bowl and not allowing the fuel into bowl.
That @#$%^&!!! KZ650! 19 Nov 2016 12:19 #748365
  • tfh903
  • tfh903's Avatar
here are pics
That @#$%^&!!! KZ650! 19 Nov 2016 12:20 #748366
  • tfh903
  • tfh903's Avatar
can't get them to go
That @#$%^&!!! KZ650! 19 Nov 2016 12:34 #748368
  • tfh903
  • tfh903's Avatar
try again
That @#$%^&!!! KZ650! 19 Nov 2016 12:36 #748369
  • KZB2 650
  • KZB2 650's Avatar
Forgot about this...I added bowl lines and on the 2 vent lines one day after having them open to the air for years and had this problem.... went home and took em off and things right away went back to normal...... need to route some on my over flow vents out of the air steam someday and may try this.
1978 KZ650 b-2
