GPZ1100 Frankinbike is close to finished 01 Sep 2016 05:38 #740763
  • Bozo
  • Bozo's Avatar Topic Author
  • Ride it like u stole it
  • Thank you received: 104
For some time I've been adding pictures of my frankinsaki on others postings, now its close to being finished so I thought I'd share my pictures. I'm still waiting for some gold KAWASAKI tank
, 1100R sidecovers and ducktail emblems from Webike.
Enjoy
Third ride is now the Frankenstein 1981 GPZ1100B1, getting new/ refurbished 83-84 motor soon
Forth my work bike FJ1200 1989 (same type as above)
GPZ1100 Frankinbike is close to finished 01 Sep 2016 06:23 #740765
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1987
Always Love your work Mate ;)
Dave B) B) B)
The following user(s) said Thank You: Bozo
GPZ1100 Frankinbike is close to finished 01 Sep 2016 07:05 #740768
  • Bozo
Thanks Dave your opinion is always appreciated.
For the purists that have other opinions of this bike, please note it was built from spares I had in my back shed, everything modified was either hand made (I don't have special laths or milling machines) or bought cheaply (budget). I also played around with the painting myself (I never spray painted before).
GPZ1100 Frankinbike is close to finished 01 Sep 2016 08:45 #740776
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
  • Thank you received: 245
Looks sweet! Details? What pipe is that?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
GPZ1100 Frankinbike is close to finished 01 Sep 2016 12:59 #740793
  • baldy110
  • baldy110's Avatar
  • Thank you received: 510
Wow, spectacular work, I really love the look. And like he said what pipe is that, I like how high it comes up in the back.
GPZ1100 Frankinbike is close to finished 01 Sep 2016 13:32 #740800
  • LesbianSeagull
  • LesbianSeagull's Avatar
  • Here to end my reverse Midas touch curse
This bike looks awesome !
Some days you're the windshield. Some days, you're the bug.
GPZ1100 Frankinbike is close to finished 01 Sep 2016 14:53 #740811
  • mopguy
  • mopguy's Avatar
  • Thank you received: 168
Very nice work, bike looks great.
GPZ1100 Frankinbike is close to finished 01 Sep 2016 16:16 #740824
  • Bozo
Kidkawie wrote: Looks sweet! Details? What pipe is that?
The pipe is Marving, the headers are for the GPZ1100 '81 and the tail is a street Z1R so on the GPZ it angles up more than normal. It is very quiet and does rob some power compared to the racing pipe (which looks different but goes like stinks- see my Z1R). I might at a later stage fit the racing pipe (which by the way is not that loud). I've had plenty of pipes in my time but the Marving has to be the best (my FJ1200 also has the enduro pipe).
The Frankinbike as a mixture of the following -
GPZ1100 '81 engine, had only 80kms when the bike was written off (although the engine number is referenced to '83 - go figure).
The engine was minus head so a fitted a Z1000J head, I ported it and the valves were new. I honestly don't remember how/when I got this head but it is like new. Cams fitted are from a GPZ1100 83 model, Its not that wild as the pistons are totally standard "81. Time will tell.
Lights are LED - Chinese but my budget dictates what I have.
I rewired a new loom myself.
Front brake master cylinder is from a GTR1400 shafty, it is a radial and the brakes are excellent considering the standard calipers.
The switch blocks are cheap Chinese.
Carbies are ZRX1200, with Dyna jet - same as my Z1R
Frame (Z1000J) is modified to mono shock GPZ900/750?
Front end is mixture of GPZ900R and GPZ1100'81.
Wheels are from a Honda CBR1000F 2006 (nice and wide), I got these dirt cheap with tyres (like new). Front bearings were changed with a smaller diameter inner to suit GPZ900R axle, there is no speedo drive as the speedo is a speedhut GPS with fuel gauge.
Gauges are from a GPZ1100 '83.
Paint colour is a Empire Bronze 401A, 2 pack
This is what I had 8 months ago (the engine cases were my other spare set)
Last edit: by Bozo.
GPZ1100 Frankinbike is close to finished 01 Sep 2016 18:13 #740837
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
Nice mix and match of parts there mate, I really like what you've done with the gauges, they look right at home on that bike. Apart from the speedo, was there much converting with the wiring..? What harness did you use..?
GPZ1100 Frankinbike is close to finished 01 Sep 2016 19:15 #740842
  • Bozo
750 R1 wrote: Nice mix and match of parts there mate, I really like what you've done with the gauges, they look right at home on that bike. Apart from the speedo, was there much converting with the wiring..? What harness did you use..?
The loom was tailor made, as you can see in the picture, I used heavy wires to relays (coils, horn etc). The front LED uses little power so general switching was used. Since I work in electronics it didn't take me long to set this up. Some switching that Kawasaki uses was the reverse of what I thought it would be for the idiot lights so I had the use low current relays ( second picture shows small relays)
The following user(s) said Thank You: Kray-Z
Last edit: by Bozo.
GPZ1100 Frankinbike is close to finished 01 Sep 2016 19:59 #740850
  • 750 R1
  • 750 R1's Avatar
Nicely done, wish I had the skills to do that...!!
GPZ1100 Frankinbike is close to finished 01 Sep 2016 23:16 #740853
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
  • Thank you received: 107
That is what a big Zed should be.
A fine job, and "inspirational" - really!
After seeing your posts and another with a re-motored 82 750 ELR replica, I'm now working on leads to gather the raw material to build one myself - 83 GPz1100 Engine, 82 GPz750 Chassis.
Thanks!
