Hamasaki 2.0 17 Aug 2016 13:01 #739027
  • Rustyhama
  • Rustyhama's Avatar Topic Author
  • Thank you received: 19
While I'm on a 7 month no motorcycle holiday I decided to make a few modifications to the Hamasaki. Most importantly I'm hoping to deal with that smokey exhaust once and for all and I decided I didn't like the seat that I sewed myself. It wasn't a bad job but the shape is not quite right and I think a beautiful seat is like the icing on a cake for a custom bike.
Cheers
Hama
82 KZ 305 - Hamasaki cafe racer
80 KZ 750 - banished
06 KDX 200
Hama
'82 KZ305-B1 Cafe Racer
'80 Z750E project
www.dotheton.com/forum/index.php?topic=59260.0
Last edit: by Rustyhama.
Re:Hamasaki 2.0 17 Aug 2016 15:31 #739037
  • Rustyhama
Because I sourced the last set of stock rings on the planet (I know of 1 set for 1 piston) and my rings did not seem to seat correctly I began a search for alternatives. I found Wiseco do a big bore kit for the GPz 550 that has a 61mm bore and a stroke of 52.4 that matches the stock pistons for the KZ 305. So I bought a set and found that the 305 has a 15mm wrist pin and the 550 a 14mm, I'm still waiting for the wrist pins to arrive but the plan is to get the pistons machined to take the 15mm pins and snap rings.
Perfect match!
Cheers
Hama
06 KDX 200
Hama
'80 Z750E project
Re:Hamasaki 2.0 18 Aug 2016 02:04 #739082
  • Rustyhama
I'm working on my new seat and side covers. added some polyurethane foam to the sides. shaped the foam...
3 layers of fibreglass and some bondo work (and lots of messy sanding) almost ready to go to my painter.
I like the look of the vintage oval number plates so I'm using that idea for my new side covers to fill in the dreaded KZ frame droop. I had just enough 2mm aluminum sheet left. I made a plywood template and whacked it into shape with a rubber mallet. cut out the shapes with a jigsaw. I used my cutting blade on my angle grinder to score the back face then used my vice and mallet to fold them. . They will be painted to match the rest of the bike.
Cheers
Hama
06 KDX 200
Hama
'80 Z750E project
Re:Hamasaki 2.0 18 Aug 2016 06:29 #739108
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
nice work you have done here sir :evil: !
can't wait to see it upholstered and painted,
Hamasaki 2.0 20 Aug 2016 19:46 #739350
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Yes, I like what you've done too.
B)
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Re:Hamasaki 2.0 26 Aug 2016 03:57 #740003
  • Rustyhama
Seat all masked up ready for fiberglassing the base for the foam and for the leather to be fixed to. I thought I had a photo of the wet second coat but I don't. I'll get a snap on the finished piece tomorrow.
My part engine parts have all arrived and have now been sent away for machining. I hope the do a 100% perfect job!
Cheers
Hama
06 KDX 200
Hama
'80 Z750E project
Re:Hamasaki 2.0 26 Aug 2016 04:12 #740005
  • Rustyhama
This is what I gave them... Damn pdf won't upload. I'll do it on the computer tomorrow...
Hama
'80 Z750E project
Hamasaki 2.0 26 Aug 2016 14:01 #740059
  • DannyKZ
  • DannyKZ's Avatar
  • 2 KZ400's
Wow! I really like what you're doing with the seat and side covers! Great craftsmanship!
Life's a tour, not a race. Just stay out of my way when I'm touring.
Re:Hamasaki 2.0 29 Aug 2016 23:04 #740481
  • Rustyhama
Here's the fiberglass base for the foam. Leather in transit from Napa California. I need to sort the fixings next, I have a plan for that.
Cheers
Hama
06 KDX 200
Hama
'80 Z750E project
Hamasaki 2.0 29 Aug 2016 23:09 #740482
  • Rustyhama
Attachment KZ30561mmPistonDetails.pdf not found
Hopefully my plan uploads today. This is what I gave the engineers - surely the can't cock it up from here...
Hama
'80 Z750E project
Re:Hamasaki 2.0 29 Aug 2016 23:15 #740483
  • Rustyhama
Side cover fixed in place
Cheers
Hama
06 KDX 200
Hama
'80 Z750E project
Re:Hamasaki 2.0 30 Aug 2016 05:51 #740495
  • 531blackbanshee
  • Vendor
nice! :evil:
