  • Page:
  • 1
1983 kz750 spectre 05 May 2016 00:05 #724652
  • Django89
  • Django89's Avatar Topic Author
  • Thank you received: 0
Im looking to do a couple of things to my bike and i looking for info on some thing's. I want to o
Do a chain conversion. Im looking at a 1982 kz750 e3 output shaft. Is this going to work with my bike? Second what rear swing arm will work qoth my bike? And im looking to replace my.front forks. I thinking usd forks. Whats the best to use? 99 r1 front end. And im looking for and output shaft backplate
1983 kz750 spectre 05 May 2016 22:34 #724839
  • Django89
Anyone
1983 kz750 spectre 06 May 2016 05:24 #724846
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
I've never heard of a shaft-to-chain conversion on a 750, but I'd guess it's possible since it has been done on the 1000s.
It's going to take quite a bit of work as I'm pretty sure you'll have to split the crankcase.
Here are a couple of topics. google search = kz1000 shaft drive chain conversion. you can try other searches.
KZRider topic --- 1979 KZ1000 shaft to chain conversion --- by SpikeJ
This is an old topic. he mentions a photo blog that might still be floating around the internet somewhere.
custom fighters --- SpikeJ topic --- see reply by Mustapha-dump
He provides some of the particulars.
Forks. search KZR for KZ750 fork swap or something like that. All-Balls-Racing has a cross-reference for figuring out what fits what. Basically, there have to be bearings that will mate the donor steering stem to your frame, then have the steering stem machined --- I guess cut to the correct length, then the end re-machined or something like that.
Rear end. do a KZR search for KZ750 swing arm swap.
Last edit: by martin_csr.
  • Page:
  • 1
