My C-10 Concours 10 Feb 2016 13:02 #710311
  • kzz1king
  • kzz1king's Avatar
  • Thank you received: 52
Got the parts out of the shed today. Got both trucks stuck doing it :angry: Thank goodness for winches :) Here are some pics Dave. Shipping is going to be pricey . I want to make sure you think they are worth it. Some cracks and patched tabs. JD Weld slowset and hardware cloth made some good fixes on the inside of the panels. Some use ABS glue and even add in ABS shavings.
Home built KZ1000 turbo setup
My C-10 Concours 10 Feb 2016 13:03 #710312
  • kzz1king
  • kzz1king's Avatar
Attachment DSCN5351-2.jpg not found
Attachment DSCN5352-2.jpg not found
Attachment DSCN5353-2.jpg not found
Attachment DSCN5354.jpg not found
Attachment DSCN5356.jpg not found
My C-10 Concours 10 Feb 2016 13:48 #710317
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2649
A little fiberglass and ABS glue will fix that. Next time I repair ABS parts I'll embed the glass in the glue then resin over it.
My C-10 Concours 10 Feb 2016 16:41 #710343
  • diego092409
  • diego092409's Avatar
  • Thank you received: 4
I have a 1997 concours that my wife and I enjoyed for the 4 seasons of riding that we had it. By far the best upgrade was a shock from a c14. I used the bottom bolt from the stock bolt to make a bushing. My wife loved it because it stopped bottoming out. Only issue is the side stand is now too short.
Check out zggtr.org and concours.org two great communities albeit it a little obsessed with hydrolock
1982 KZ1100 B2 - 'Old Red' kzrider.com/forum/11-projects/601185-gpz-1100-resto-mod-old-red
2015 BMW K1600GT
2017 KTM 690 Enduro R
2018 Kymco Spade (wife's)
Last edit: by diego092409. Reason: want to add something
My C-10 Concours 10 Feb 2016 16:44 #710345
  • SWest
  • SWest's Avatar
  • 10 22 2014
Get one from a smaller bike?
My C-10 Concours 10 Feb 2016 17:11 #710354
  • zukdave
  • zukdave's Avatar Topic Author
  • Thank you received: 229
swest wrote: Get one from a smaller bike?
My stock one is to short now bike lean's over to much for me.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
My C-10 Concours 12 Feb 2016 02:16 #710557
  • diego092409
I just put it on the center stand all the time, with the longer rear shock, it is really easy to get up on the center stand. I am planning to strip it down and make it a commuter bike when the weather gets warmer. I took the headlight off my GPZ1100 for the resto mod, may put it on the connie just so it has a headlight.
2015 BMW K1600GT
My C-10 Concours 12 Feb 2016 03:50 #710567
  • diego092409
I also put the front brakes from an RC-51 on my bike, Helped with stopping. The brakes on the connie are the same pattern as the suzuki bandit and this is an upgrade a lot of bandit owners do . There is a company that sells mounting adapters. Along with some spacers from McMaster Carr it went right in.
www.svracingparts.com/store/#!/SV650-All...2829/category=484220
McMaster Carr Part No 92510A356 for the spacers
2015 BMW K1600GT
