Thinking about building a trike 03 Jul 2016 10:51 #733706
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
That is going to look very cool B)
So are you going to stay with the original wheel base?
I think that will help keeping the original geometry as far as the ride goes.
I do like the way it looks stretched out :evil: but I think it would need to be raked and longer tubes and who knows how it would handle then.
78 KZ1000 A2A
Thinking about building a trike 03 Jul 2016 16:49 #733730
  • larriken
  • larriken's Avatar
  • Thank you received: 61
KZQ wrote: I'm sure it's not going to be fast, not with all the extra weight. I'd read somewhere that the 750 twins do well when mated to a sidecar because of the good low end torque.
So here I go.
Bill
Love what you are up to on this build! Here is a Z750 that a local bike shop I used to live near used to do all their bike pick ups with. I hadn't seen it in years and then it reappeared in the carpark at a bike show. They used to load up with rider, side chair, and a big cc bike and haul off no worries.
Last edit: by KZQ.
Thinking about building a trike 03 Jul 2016 21:36 #733745
  • KZQ
  • KZQ's Avatar Topic Author
  • Administrator
  • Thank you received: 1278
bluej58 wrote: That is going to look very cool B)
I'm going to keep it as close to the original wheelbase as I can. Lacking a reverse it's already going to be a bearcat to turn around. If I let it get too long I'll need a whole parking lot to get it maneuvered around.
I laid out the cuts on the swing arms and drew the spreaders with my CAD program. I've got to go to Boston next week but not before I send the drawings off to the lazer cutter. Hopefully they'll be done when I return home.
Thanks
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: by KZQ.
Thinking about building a trike 05 Jul 2016 09:20 #733964
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
nice to see some progress bill!
keep us posted,
Thinking about building a trike 16 Jul 2016 08:33 #735118
  • KZQ
  • Administrator
Finally got some time to get back on the trike.
Here I'm fitting up the dogbones to the swing arm. I'm mocking it up backwards just to use the pinch blocks for alignment.
I'll have it all welded up later today.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Thinking about building a trike 16 Jul 2016 08:38 #735120
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2624
Looks strong enough to me. Is that a differential rear end? B)
Thinking about building a trike 16 Jul 2016 09:26 #735128
  • KZQ
  • Administrator
Hi Steve,
It's gonna need some bracing and I've got to weld in the bottoms of the loops. You can see the notches below the swing arms. Yes it's a chain drive differential.
Here's a question: After the swing arm is all welded up. Does anybody see anything wrong with just welding two of the pinch blocks to the axle tubes?
Others who have used these axles have added bolt on spacers to keep the differential correctly aligned/centered and also to account to the twisting forces that result from accelerating and braking.
This axle uses greased bearings instead of gear lube so the axle tubes are not full of liquid.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: by KZQ.
Thinking about building a trike 16 Jul 2016 11:59 #735152
  • SWest
  • SWest's Avatar
  • 10 22 2014
Distortion is the only thing I can think of. I had a small one bolted to a 350 Honda frame. The PO used it on a small dirt bike. He welded a cage around it to keep it from flexing in the middle. It worked great.
Thinking about building a trike 18 Jul 2016 13:10 #735345
  • 531blackbanshee
  • Vendor
nice work.
if you are talking about welding say the inside pinch blocks to the tube so they stay put.
i don't see a problem with it.
Thinking about building a trike 21 Jul 2016 15:24 #735764
  • KZQ
  • Administrator
I'm getting closer. Next step is to weld on some connections or tabs for the lower ends of the shocks.
Regards
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Thinking about building a trike 22 Jul 2016 05:41 #735815
  • 531blackbanshee
  • Vendor
nice!
i like the proportions :evil:
how wide is it outside to outside ?
Thinking about building a trike 27 Jul 2016 21:01 #736451
  • KZQ
  • Administrator
Hi Leon,
Outside of tire to outside of tire is 50".
I took the axle apart enough to relocate the brake calipers so that the bleeds are at the top. I also added the lower shock mounts so the bike stands on it's own. Next step is to purchase a 530 chain that's 144 links long. I'm thinking that it'll end up being 132 links once I've got the axle adjusted and tightened up. After that I've got to plumb the rear brakes which will be a combination of flaired 1/8" steel and some short braided lines to allow the axle to be moved forward and aft to adjust the chain.
Here's what it looks like presently:
What do you think?
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: by KZQ.
