Fuel Tank and Pet Cock Problems 19 Aug 2015 08:36 #686364
  • Mikaw
  • Mikaw's Avatar Topic Author
  • Thank you received: 1863
Not sure if this is the right forum please move if I PICKED WRONG.
The Tank Kreem has decided it didn't want to stay attached to the sides of the tank and all settle along the bottom and into the petcock. The tank cam to me this way some 30 years ago so I cant take responsibility for the condition. Anyway now that my conscious is clear, How do i remove the gas impregnated silly puddy from the tank. More important is how do i replace the filter on the petcock that is in the reserve circuit of the valve. the little 1/4' x 1" filter is completely filled with the silly puddy looking Kreem.
Attachment DSCF4092.jpg not found
Fuel Tank and Pet Cock Problems 19 Aug 2015 16:22 #686410
  • Irish Yobbo
  • Irish Yobbo's Avatar
  • Thank you received: 93
Common method is to put a handful of screws in the tank along with paint stripper and give it a good shake and soak - the screws will knock all the loose bits from the side.
I'd give your petcock a blast with an air compressor - 100psi down the lines should clear it up nicely :)
1981 KZ750 LTD
Fuel Tank and Pet Cock Problems 19 Aug 2015 16:46 #686416
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2626
Take the sediment bowl off and spray through the openings with carb spray then air pressure. The tank? I'd get out all the loose stuff I could. Stripping it all out is MURDER.
Fuel Tank and Pet Cock Problems 19 Aug 2015 17:38 #686420
  • mike1957
  • mike1957's Avatar
  • Thank you received: 8
There's a lot of ways to clean a tank out most important is to get all the rust dirt and anything else out of it.
Takes a lot of time but the prep is most important.Once you get that done. You can use a sealer.I've used por15 and had good
results. There are a lot of other brands out there .Hope this helps Here's the link to the por 15 site. If you can find a tank in good shape clean inside no dents it might come out cheaper and a lot less work than cleaning your's out and re sealing it.
www.por15.com/POR-15-Motorcycle-Fuel-Tan...pair-Kit-_p_106.html
mike1957
Fuel Tank and Pet Cock Problems 19 Aug 2015 17:56 #686423
  • Mikaw
Irish Yobbo wrote: Common method is to put a handful of screws in the tank along with paint stripper and give it a good shake and soak - the screws will knock all the loose bits from the side.
With all due respect the screws would get sucked up in the soft puddy like gas impregnated goo. the tank has been sitting over night and some of the primordial goo has oozed out of the petcock bung. Brake clean wont cut it either.
swest wrote: Take the sediment bowl off and spray through the openings with carb spray then air pressure. The tank? I'd get out all the loose stuff I could. Stripping it all out is MURDER.
Again I don't think you understand what I'm up against. The kreem has turned into a gooey puddy like substance that oozes out of the tank after it sat over night with the petcock removed. As for the petcock I pulled it apart and cleaned the best i could that's when i noticed the short filter on the reserve circuit was completely filled with the kreem puddy. I squeezed the filter and the kreem slowly oozed out but in the process I damaged the filter. Is it replaceable?
Fuel Tank and Pet Cock Problems 19 Aug 2015 18:08 #686425
  • Mikaw
Here is a picture of what I'm up against. I removed the petcock late yesterday. The tank sat over night and when I lifted it to move it I noticed the gooey ooze working its way out of the tank.
Attachment DSCF4093.jpg not found
Attachment DSCF4096.jpg not found
Fuel Tank and Pet Cock Problems 19 Aug 2015 18:18 #686427
  • Thank you received: 2829
You may want to try Acetone or MEK. Read their precautions first. Ed
Fuel Tank and Pet Cock Problems 19 Aug 2015 18:23 #686430
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Yuk! I'd start looking for a rusty replacement tank and clean the rust out rather beat my head against a wall removing Kreem
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Fuel Tank and Pet Cock Problems 19 Aug 2015 18:27 #686431
  • SWest
  • SWest's Avatar
  • 10 22 2014
Contact them. If nothing can be done, I'd get another tank. I've heard horror stories about that stuff.
Fuel Tank and Pet Cock Problems 19 Aug 2015 19:09 #686434
  • Mikaw
Yuck Is right. It has slid down the inner walls of the tank a settled along the pinch welded seams. Good point is the tank really isn't that bad. I bet it would just take a douche of vinegar and she'd clean right up IF i can get the goo out.
How about the filter on the petcock. I've been surfing and haven't had any luck finding one or any of the seals...
Fuel Tank and Pet Cock Problems 19 Aug 2015 19:40 #686437
  • SWest
  • SWest's Avatar
  • 10 22 2014
They don't sell just the strainers.I bought a new one but the main strainer was broken. I use a in line filter. I should have sent it back to z1partsinc but I needed it now. If you find one, let us know.
This member just went through stripping his tank.
kzrider.com/forum/11-projects/367864-oh-...300?start=120#684307
Fuel Tank and Pet Cock Problems 19 Aug 2015 19:44 #686438
  • SWest
  • SWest's Avatar
  • 10 22 2014
