1982 KZ1100-A2 Shaft Project 05 Jan 2015 12:07 #657841
  • jeffw
  • jeffw's Avatar Topic Author
  • Thank you received: 2
I finally picked up a new project to work, been looking for another KZ and couldn't pass up the deal on it. Will have extra parts if anybody is interested before I post it on Ebay. The bike was a full dresser with all the accessories and is not my cup of tea.
This is my attempt at photoshop on what I want to do.
1977 KZ650 B1 "Cafed"
4-1 & Pods, Electronic Ig. & Dyna Coils
forums.kz650.info/index.php?topic=9020.0 - SOLD :(
1982 KZ1100 A2 Stripper
kzrider.com/forum/11-projects/596850-198...100-a2-shaft-project
Last edit: by jeffw.
1982 KZ1100-A2 Shaft Project 05 Jan 2015 12:08 #657842
  • jeffw
More progress on the bike did leak down test and all cylinders less than 10% (cold) that is really good. Here are some progress photos.
Frame prepped for hoop
Engine
Parts are slowly coming in, experimenting with indicator panel, and metal for seat pan & battery box
1982 KZ1100-A2 Shaft Project 05 Jan 2015 12:08 #657843
  • jeffw
More progress pics, I have figured out rear sets. Took a shoot in the dark by buying some r6 rear sets for cheap off Ebay.
A piece of flat plate (will shape to match existing) and an extra bolt. Almost fits perfectly, even existing bolts from R6 rearsets thread into existing threaded hole. Won't know until its back together whether I will have any clearance issues.
1982 KZ1100-A2 Shaft Project 05 Jan 2015 16:01 #657853
  • Puffin
  • Puffin's Avatar
  • Thank you received: 32
Nice project Jeff B) im likeing your photoshop projection. One things for sure without all that junk on the bike will be a better ride. Keep us posted
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
The following user(s) said Thank You: Hoover
1982 KZ1100-A2 Shaft Project 15 Jan 2015 06:14 #658751
  • jeffw
More progress on bike, welded loop on and welds cleaned up.
Engine cleaned up and painted, still need to shine up covers
Seat pan built and bent
Indicator panel built
New 12 Cell battery, still brainstorming on how to attach to engine
1982 KZ1100-A2 Shaft Project 15 Jan 2015 13:20 #658785
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
jeffw wrote:
[/URL]
Nice project. in this photo it looks like the brake pedal is angled up quite high. I'm not sure what kind of adjustability you have on that, but you may need to revisit it. All the rearsets i have ever ridden the brake pedal is below the foot peg quite a bit. Keep up the progress.
1982 KZ1100-A2 Shaft Project 15 Jan 2015 14:26 #658790
  • jeffw
Ya I agree I have been looking at and scratching my head, whether I rotate the whole assembly with a bracket or see if I can rotate/bend the lever somehow
1982 KZ1100-A2 Shaft Project 15 Jan 2015 16:28 #658799
  • Shimmy
  • Shimmy's Avatar
  • Thank you received: 15
I'm not sure how it's set up, but maybe you could lower the pedal by moving or adjusting the master cylinder? In any case, looking good!
1980 KZ750 LTD
Edmonton, Alberta
1982 KZ1100-A2 Shaft Project 16 Jan 2015 10:38 #658844
  • kzspartan
  • kzspartan's Avatar
Before you go any further, check to see on the shifter (left side) if you have clearance with the kickstand up. Sometimes we over look the obvious.
Cool Build!
1982 KZ1100-A2 Shaft Project 16 Jan 2015 11:52 #658849
  • jeffw
I think I will be alright as the linkage comes off from the top of the rearset, but plan to get all mocked up before I start messing with them.
1982 KZ1100-A2 Shaft Project 16 Jan 2015 14:08 #658856
  • calvinhobbesfan92
  • calvinhobbesfan92's Avatar
I'm interested to know how you made the loop for the back. I've got a bike that I will be welding the same exact thing on. Did you bend it yourself or buy it?
83 Kawasaki Spectre 550 Bobber
1982 KZ1100-A2 Shaft Project 16 Jan 2015 14:37 #658862
  • jeffw
No eBay APP ID and/or Cert ID defined in Kunena configurationI bought it from a guy on Ebay that was willling to bend it to the correct width, and as you can see fit pretty nicely.
Match industries is the name of the company.
The following user(s) said Thank You: calvinhobbesfan92
