  • Page:
  • 1
  • 2
kick starter 07 Nov 2014 07:47 #653138
  • gtrain
  • gtrain's Avatar Topic Author
  • Thank you received: 0
Hi, been a member for a while, purchase my first Z1 a few years ago, always wanted one. Its been a slow project, but getting near the end. Going to put up some pics of my progress.
Attachment IMG_0349Small.jpg not found
Attachment IMG_1844Small.jpg not found
Attachment 20121007_192333Small.jpg not found
Last edit: by gtrain.
kick starter 07 Nov 2014 07:56 #653139
  • gtrain
Frame was bend.
Attachment milduratrip22122012009.jpg not found
Attachment milduratrip22122012010.jpg not found
Starter clutch missing.
Attachment phonepics070.jpg not found
kick starter 07 Nov 2014 08:40 #653142
  • gtrain
Another back frame section welded on, frame braced, modify shocker mounts for ZRX swing arm and straightened, and expensive exercise at the bike engineers.
Attachment IMG_0489.jpg not found
Attachment IMG_0490.jpg not found
Attachment IMG_0491.jpg not found
Attachment IMG_0492.jpg not found
kick starter 07 Nov 2014 08:49 #653143
  • gtrain
A donor bike for wheels, forks, brakes, and other bits and bobs.
Attachment IMG_0423.jpg not found
Re:kick starter 07 Nov 2014 09:12 #653147
  • kaw-a-holic
  • kaw-a-holic's Avatar
  • Thank you received: 248
Look'n good!
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
kick starter 08 Nov 2014 10:28 #653215
  • gtrain
Reco cylinder head, Old head had bent valves, big cracks throw spark plug threads into valve seats. Had two crankshaft bearings replace rust damage from seating for 25 years bored cylinders and fitted a cruise image piston kit from ebay, new timing chain, chain rollers Ape chain tensioner,new clutch assembly, sand blasted cases myself, painted engine with VHT satin black case paint, new polished covers.
kick starter 26 Dec 2014 02:22 #656973
  • gtrain
pictures of painted motor
Attachment kzrpic1Small.jpg not found
Attachment kzrpic2Small.jpg not found
Attachment kzrpic3Small.jpg not found
Attachment kzrpic4Small.jpg not found
kick starter 26 Dec 2014 07:36 #656982
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2630
If it's taching too high at speed because of that 16" rear wheel, you can switch to a 16 tooth counter shaft sprocket from the stock 15.
kick starter 02 Jan 2015 08:00 #657576
  • gtrain
Pics, with ZRX swingarm, Bandit wheels and forks, not sure if there is enough steering lock with suzuki triple clamp, after modifying the steering stop to prevent forks hitting tank?
Attachment IMG_0432Small.jpg not found
Attachment IMG_0436Small.jpg not found
Attachment IMG_0494SmallSmall.jpg not found
Attachment IMG_0488Small.jpg not found
kick starter 09 Jan 2015 01:58 #658133
  • gtrain
I've modified a Mitsubishi trans cooler to work as a engine oil cooler, hope it doesn't restrict air flow to the head.
still not sure about that steering lock? May look for a triple clamp with a bigger offset for more lock, and keeping
forks away from tank, any suggestions?
Attachment IMG_0560Small2.jpg not found
Attachment IMG_0561Small.jpg not found
kick starter 09 Jan 2015 07:07 #658158
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
projects coming along nicely sir.
i believe the steering lock is only going to be a problem on low speed turnarounds in the road and such.
keep us posted,
  • Page:
  • 1
  • 2
