Attachment ImageUploadedByTapatalk1415207423.464035.jpg not found
New swing arm
Attachment ImageUploadedByTapatalk1415207461.097322.jpg not found
Off set front sprocket for 190 tire.
Can't remember the exact gearing right now but I think it's around equivalent to the z1r gearing but in a 525 chain.
Attachment ImageUploadedByTapatalk1415207583.848703.jpg not found
Attachment ImageUploadedByTapatalk1415207694.597795.jpg not found
Attachment ImageUploadedByTapatalk1415207709.063987.jpg not found
These are the new handlebar mounts. I didn't want to run the clip ons that came with the front end so I will be running some plain old 7/8 drag bars instead.
Attachment ImageUploadedByTapatalk1415207805.980631.jpg not found
That's the zx ignition. I will be discovering how to wire that soon. I figured running it instead of the kz ignition would be easier to mount as it already has a spot in the triple tree but who knows how much easier it will be in the long run.
Attachment ImageUploadedByTapatalk1415207917.381825.jpg not found
Bottom of the bottom triple tree. For the steering damper.
Attachment ImageUploadedByTapatalk1415207953.448563.jpg not found
It mounted perfectly to where the reflector goes. It had to be mounted to the tree instead of around the forks because of clearance issues. But now it turns full stop without binding on anything.
Attachment ImageUploadedByTapatalk1415208101.247371.jpg not found
Rear brake is almost done. New braided line.
Attachment ImageUploadedByTapatalk1415208147.568570.jpg not found
Using the original kz master cylinder and brake pedal for figment to run the zx 10 caliper. Even the newer brake is just a single piston. I think that's about it. I started shooting some primer on my body parts last week. Scored a vintage kz 900 tail, complete with registration tray and safety check list sticker!
