This is what $200 got me
- ramtough_63
Rule of Zeros
Pay zero attention what the previous owner says it needs
Pay zero dollars for parts until you confirm its necessary
Pay zero attention book values
Pay zero dollars to local bike guru
Pay zero attention to your wife/friends
Pay retail for a shop manual learn to use a test light
Pay zero Attention to the urge to tear it completely apart before you ever ride it
Pay your internet bill you will need the access
on second thought maybe it should be the rule of paying but either way take your time its amazing
what you can accomplish in a weekend.
my daily job consists of consumers walking in the door telling me all it needs is an alignment
after they spend 80 dollars for my alignment tech to do an alignment because they are always a little out I find out it has a tire pull & rotate the tires for 15 bucks and its all good again.
Make sure you jump the solenoid before you layout any money for a starter or other components. confirm whats bad before replacing anything. read up and ask questions is my best advice.
A good friend of mine road one of those forever I ben trying to talk him out of it for last couple of years
didn't last year maybe this year
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- chconger
Have you tried to start it? What happens?
Chris
1977 KZ 1000-A
- MannDude
- Thank you received: 1
Unsure if the battery is still charged right now, charged it up a few months ago when I got it. It worked then, lights come on and stuff. Turning the key in the ignition resulted in the feeling that something tried to turn. Only tried it once. I'll spend some time with it this weekend.
- lindseyss
- Thank you received: 3
- chconger
Pull the tank off, drain it and put in fresh gas. Assume what you have is bad.
Try again. When you do..only hit the starter for short bursts at a time. Dont hold the starter for longer than 2-5 seconds. Let it cool and recover.
That's the best, cheapest, chance to get it to fire for you.
If you get nothing then there are ways to figure it out. Let us know.
Probably want to get a cheap volt /ohm meter to add to the tool kit in your avatar.
Cheers
Chris
1977 KZ 1000-A
- ThatGPzGuy
- Thank you received: 385
If the starter is bad (and you won't know until you do the diagnostics) then look for a rebuilder near you. It is usually much less than buying a new /rebuilt one and you get a better guarantee.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Forrest
- The Mad Duck
- Thank you received: 180
BTW, I just snagged a two stroke Kawasaki enduro for $178.50. It looks good enough I may not cannibalize it for parts but end up with two two strokes! :woohoo:
- MannDude
lindseyss wrote: Here is my 81 LTD same color. That was a great buy I wouldn't sell mine for that for sure with 17k miles. Once you get it running check to see if you have a leak between the cylinder and head those old rubber seals like to leak on these old girls.
Great looking bike! I'm hoping mine will look that good by the end of this summer, however at this point I just want her to turn on and purr for me.
After that, then comes the cosmetic stuff.
- lightitup
- Thank you received: 10
81 kz 550 ltd
