650 Mod's 78 custom build 25 Feb 2013 22:07 #574143
  • 650mod
  • 650mod's Avatar Topic Author
  • Thank you received: 48
Sorry, here's the rest of the pictures
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
650 Mod's 78 custom build 25 Feb 2013 22:08 #574144
  • 650mod
...and the tank...
Attachment IMGP2233.JPG not found
78 kz 650 custom
650 Mod's 78 custom build 14 Mar 2013 16:44 #576949
  • 650mod
Went to the post office today, and it was like Christmas all over again! I got the last few parts in that I'm needing for the build, and made a run to the border to get a few more packages.
Tires are mounted up, rotors are on, and I'll be doing front end work this weekend!
Colortune unit to finally get my carbs all balanced properly
Attachment IMGP2257.JPG not found
Some Gord's Aluminum Polish to get a mirror shine on the aluminum
Attachment IMGP2258.JPG not found
Nice gold 530 chain
Attachment IMGP2259.JPG not found
My BEEFY headlight brackets- these things are almost a pound each...
Attachment IMGP2261.JPG not found
Nice little new fuse box to get rid of the old barrel fuses
Attachment IMGP2262.JPG not found
Flyscreen for the headlight, break a bit of the head on wind
Attachment IMGP2263.JPG not found
Front wheel- the nice 13" Buell rotor
Attachment IMGP2264.JPG not found
Rear rim with the Pirelli Diablo 180/55
Attachment IMGP2265.JPG not found
More pics will be up with the progress on the front end this weekend :)
78 kz 650 custom
650 Mod's 78 custom build 14 Mar 2013 19:58 #576974
  • mike0537
  • mike0537's Avatar
  • Thank you received: 6
Loving the gold wheels!!!!!!
1980 KZ750E
650 Mod's 78 custom build 14 Mar 2013 20:16 #576976
  • 650mod
Mike,
Wait til you see the end product ;)
Devin
78 kz 650 custom
650 Mod's 78 Fighter Build 16 Mar 2013 18:56 #577239
  • 650mod
Got a bit of work done on the front end today. Dropped the old forks, got the steering stem out, and made a game plan for getting the old stem into the new triples. Ran into a small problem with machining the old steering stem down. Almost had the old top threading out, threaded the bolt into it to pull the threading, and the insert spun. Got that issue solved, and the rest is being tackled in the morning.
Front end off
Attachment IMGP2266.JPG not found
Old triples through the lathe, stem out
Attachment IMGP2267.JPG not found
Running the old stem down to adapt it to the new triples
Attachment IMGP2268.JPG not found
More updates tomorrow when the front is on
End product of outer lathing
Attachment IMGP2269.JPG not found
End product of inner lathing to insert the top of the new triple's steering stem
Attachment IMGP2270.JPG not found
78 kz 650 custom
650 Mod's 78 Fighter Build 16 Mar 2013 22:56 #577291
  • mike0537
  • mike0537's Avatar
I am no machinist but isn't using a 4 jaw chuck on something round kinda tough to do. I guess the 4 jaw I have you have to tighten each jaw separately which makes it obsolete with anything round.
1980 KZ750E
650 Mod's 78 Fighter Build 17 Mar 2013 15:01 #577378
  • 650mod
Mike- it is tough, but using a caliper tool to check where it sits makes it MUCH easier. We had the stem centered within 1 thousandth of an inch or smaller.
Shaving the new stem down to use the threads for the new top bolt
Attachment IMGP2271.JPG not found
Pressed the new top into place, welded it in, smooth the welds out
Attachment IMGP2272.JPG not found
pressed the new bottom into place, welded in
Attachment IMGP2273.JPG not found
Final product of the new steering stem. We were able to use the KZ stem, modified it, and pressed it into the new bottom triple. Good old hydraulic presses help in any situation!
Attachment IMGP2274.JPG not found
End product of about 7 hours of work- drops the front end ~4 inches. Should be ok for ground clearance, we'll have to see. It'll definitely give that lowered-stretched look for the final product.
Attachment IMGP2275.JPG not found
The shop that pressed my front wheel bearings in used the wrong bearings, so back to the shop it is to get this issue sorted out...
I'll finish the front end up when I get some time, hopefully soon :)
78 kz 650 custom
650 Mod's 78 Fighter Build 19 Mar 2013 23:18 #577769
  • Hollywoodmx
  • Hollywoodmx's Avatar
  • Thank you received: 16
Looking good man! Those head light brackets look familiar! :evil: :evil:
You in Canada?
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: by Hollywoodmx.
650 Mod's 78 Fighter Build 19 Mar 2013 23:37 #577774
  • donthaveakawman
  • donthaveakawman's Avatar
  • Visitor
what!!! :woohoo: those wheels look slick... if only there was a polish to leave on them that would keep them easy to clean. :laugh:
650 Mod's 78 Fighter Build 20 Mar 2013 08:24 #577810
  • 650mod
Hollywood- I do believe they're the same brackets as what you're using :P It took me a while to find brackets to fit my massive tubes (53mm) haha. Plus, for $40 I figured I couldn't go wrong. They're pretty damn beefy too! And I sure am in Canada- I'm in Thunder Bay, Ontario, about 6 hours east of Winnipeg. Where abouts are you?
Don- The rims are powdercoated with a matte interior gold powder, then I had the shop toss a clearcoat powder on top. A rinse with water, and they'll shine like new every single time.
78 kz 650 custom
650 Mod's 78 Fighter Build 20 Mar 2013 08:26 #577811
  • 650mod
Oh, Hollywood- forgot to ask. How much of a drop did you get on your front end with the fork conversion? I believe I'm looking at about a 4" drop or so, should be ok for ground clearance once the rear is done up.
Devin
78 kz 650 custom
