78 KZ1000 build (I'm learnding) 02 Dec 2011 17:20 #491138
  • Thank you received: 2098
When using reverse drill bits, there's often no need for an extractor.
Would heed tachrev's caution about being extra careful not to mar the mating surface.
May be worth considering EDM.
Good Fortune! :)
78 KZ1000 build (I'm learnding) 02 Dec 2011 18:24 #491148
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
  • Thank you received: 11
Patton wrote: When using reverse drill bits, there's often no need for an extractor.
That's what I was thinking of! :pinch:
Build Thread
78 KZ1000 build (I'm learnding) 02 Dec 2011 18:45 #491154
Am thinking "left-handed bit" and "reverse bit" are interchangeable terms meaning the same thing.
Customer: Got any left-hand drill bits?
Clerk: Yes, we have reverse drill bits.
Customer: Got any reverse drill bits?
Clerk: Yes, we have left-hand drill bits.
:lol:
Good Fortune! :)
78 KZ1000 build (I'm learnding) 02 Dec 2011 19:12 #491155
  • DoctoRot
  • DoctoRot's Avatar Topic Author
  • Thank you received: 664
Yep it definitely, says inch lbs not foot lbs. guess i should have paid more attention to this guy when i was a kid
But I did find some replacement JIS flange bolts so once those get here I'll give this a go again.
Last edit: by DoctoRot.
78 KZ1000 build (I'm learnding) 02 Dec 2011 19:36 #491159
  • Thank you received: 2829
You're lucky! When I was a kid this (see picture below) was considered educational TV. Guess which one in the pic I decided to emulate; correct - the one with the fuzzy face. :)
Attachment howdy.jpg not found
78 KZ1000 build (I'm learnding) 02 Dec 2011 19:48 #491161
aka 650zip :lol:
78 KZ1000 build (I'm learnding) 02 Dec 2011 23:37 #491196
  • ready2ryde1985
  • ready2ryde1985's Avatar
  • got to love these kzs
  • Thank you received: 4
Why cut off the pinch weld ? :huh:
Is this just for looks.
84 kz 700 a1
82 kz550 ltd
78 KZ1000 build (I'm learnding) 03 Dec 2011 19:17 #491331
  • DoctoRot
ready2ryde1985 wrote: Why cut off the pinch weld ? :huh:
Yeah, that and weight reduction :lol:
78 KZ1000 build (I'm learnding) 05 Dec 2011 07:47 #491616
  • DoctoRot
Made a little progress tonight, I removed the bolt I broke with a left hand drill bit (those are great!) and got the engine cases put back together, sans the two bolts I broke. Shifted through all gears, everything seems to be in order. I disassembled the oil pump and checked the clearances, everything checked out. I guess the oil pump gasket doesn't come in the standard bottom end kit, so Ill have to wait until that comes. But I did get my oil gate installed.
78 KZ1000 build (I'm learnding) 05 Dec 2011 18:51 #491735
  • ok2drive
  • ok2drive's Avatar
can't wait to see how this project turns out.. nice work
85 GPz 750
78 KZ1000 build (I'm learnding) 15 Dec 2011 22:27 #493308
  • DoctoRot
Havent had much time to work on anything lately, but i was able to work a little on the engine last night. I got the oil pump put back together and in the cases, got the oil pan back on, and the filter. a couple of months ago I sent my clutch basket to APE to have them install their clutch kit. I opened it one time to check it out and put it away. I guess they didn't oil it, cause after sitting on the shelf it now is rusted a bit. :pinch: Should I wet sand that off, does it matter? it is mostly on the outside of the clutch basket I also picked up this stainless engine cover bolt set at a swap meet recently. It says to use anti-seize with the bolts, so i picked up some of that. But then I was thinking, some of the bolts call for thread lock, will the anti-seize cancel out the thread lock?
78 KZ1000 build (I'm learnding) 16 Dec 2011 00:38 #493330
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
when you use stainless against stainless (stainless nuts on stainless bolts)you definately need to use anti-sieze.
when using stainless bolts in aluminum i don't use anti-sieze or threadlocker.
but if you are going to use threadlocker use the blue loctite in aluminum.
it is like it creates a barrier between the aluminum and the bolt and prevents them from gaulding.
thats been my experiance.
ymmv.
The following user(s) said Thank You: saxjonz
