Doctorot's '78 KZ1000 build
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: 78 KZ1000 build (I'm learnding)
20 Oct 2011 01:07
#484238
you scored :woohoo: !!!!!!
beats a sharp stick in the eye :pinch: :cheer:
  • DoctoRot
  • DoctoRot's Avatar Topic Author
31 Oct 2011 22:35
#486390
So I have been working on the mold for my tail piece for the last week or so, here are some pictures of the process. I just bought some more fiberglass and am starting the first layup in the mold. I'm excited to see how this thing turns out! building the flange first layer of gel coat Fiberglass rough mold cleaned and prepped mold :woohoo:
  • 531blackbanshee
  • Vendor
  • Vendor
01 Nov 2011 09:50
#486457
this would be an awesome solution for those guys that are modifying 81 and later j block 1000's.
a little whack of the rear sub frame and weld a simple little subframe back on use one of these tails and bam,pretty dang sweet.
good work doctorot.
keep us posted,
  • MajDSaster
  • MajDSaster's Avatar
03 Nov 2011 10:13
#486806
Hey Doc, I been wanting to replace the old factory shocks on my '81 LTD-1000 but have not had much luck with finding something. What are the shocks you have on there and where did you get them?
Maj.D.Saster
Current Ride: 2005 Kawasaki Vulcan 750
4th Ride: 1981 Kz1000 LTD (2008 - Storage)
3rd Ride: Wife (1999 - 2005)
2nd Ride: 1982 Kz1000 LTD (1983 - 2004)
1st Ride: 1977 Yamaha SX-650 (1981 - 1983)
  • DoctoRot
03 Nov 2011 20:37
#486885
MajDSaster wrote: Hey Doc, I been wanting to replace the old factory shocks on my '81 LTD-1000 but have not had much luck with finding something. What are the shocks you have on there and where did you get them?
Maj.D.Saster
the shocks are Works Shocks "billet dirt tracker", I had them powder the smaller spring white. They are not inexpensive unfortunately though, as they build the shock for your order, however I felt good buying USA parts and they look awesome, cant wait to try them out!
  • DoctoRot
08 Nov 2011 22:01 - 21 Nov 2011 04:59
#487690
So I have been working like crazy on my tail piece. After a few attempts and different materials I was finally able to produce this vacuum bagged beauty. Pretty stoked! I'll get some better pictures one i sand the edges down and get it a little more cleaned up. I have now started to think about how im going to mount it. Right now, the when I sit on the tail, 100% of my weight sits directly on the frame, the way i sculpted the seat part it rests directly on the frame rails including the cross brace in the back (the crosshatched oval part) I'm thinking Ill weld some tabs in the frame that it can bolt to, real simple. However the original tail piece had a mount in the back behind the taillight. Should i put one in there? Its going to stay a single, and I don't see any reason that the back would need to be supported, but if i do put weight there the tail flexes a bit.
Last edit: 21 Nov 2011 04:59 by DoctoRot.
  • Zedone
  • Zedone's Avatar
08 Nov 2011 22:51
#487706
Nice looking project Doc! (subscribed) Do you have a link for your gun? Did you outgas the cases & covers before you painted them? (just curious) They sure turned out great! Cheers, Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • DoctoRot
09 Nov 2011 01:46
#487735
Zedone wrote: Nice looking project Doc! (subscribed) Do you have a link for your gun? Did you outgas the cases & covers before you painted them? (just curious) They sure turned out great! Cheers, Doug
Not sure what outgasing is, but I got my gun here Except they were offering some deal when i bought mine so I got a 1.8 nozzle too. I was very impressed with the quality of the gun for how relatively cheap it is. Also the LVLP design gives very little over spray, well, at least compared to my 2.0 HVLP gun which seems to paint everything within a 5 foot radius of where you are spraying.
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
09 Nov 2011 02:05 - 13 Feb 2012 17:55
#487741
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 17:55 by KZ250LTD.
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
09 Nov 2011 02:12
#487743
KZ250LTD wrote: Nice job on the tailpiece!
+1 Looks great!
Did you decide to go a different way on the handlebars? It looks like you have a new set on there, but I could be wrong...
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
  • 531blackbanshee
  • Vendor
  • Vendor
09 Nov 2011 10:37
#487758
that turned out sweet! :cheer:
do you think there is any fear of the tail portion cracking over time if it is not supported? :huh:
  • DoctoRot
09 Nov 2011 21:37
#487817
+1 Looks great!
those are the same ones but on correctly now, I just turned them over to see what a lower set of bars would feel like. I am going to change the bars, have an idea cooking...
531blackbanshee wrote: that turned out sweet! :cheer:
I am a little worried, so I am scheming on a way to support it, Its in the works as we speak, Ill post some photos when its done.
Today I removed the shift drum and shift shaft and lubed everything with moly grease and reinstalled, also with new high gear shift fork. I still am curious if I should address this problem; I broke part of this bolt off, but it still holds the spring just fine. Should I get a new one machined or not worry about it?
