  • Page:
  • 1
  • 2
Were do you start 31 Jan 2010 13:05 #345626
  • jimmybon
  • jimmybon's Avatar Topic Author
  • Thank you received: 2
This is my brothers Z1A, has been in a shed on a mates farm for 20 years.
With the AU dollar high and reco parts available at cheap prices, it's time
First thing we did was spray her with insect and spider poison, next is to do a list of what is needed to give her a new lease of life, what to recondition and what to replace with new
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
Were do you start 31 Jan 2010 13:27 #345636
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
  • Thank you received: 109
invest in a big compressor and a sand blast cabinet. u will be able to refresh most of the parts to look like new.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Were do you start 31 Jan 2010 14:20 #345646
  • z650c3
  • z650c3's Avatar
  • Thank you received: 0
Take loads of pics and keep us all informed . At least its in one piece and a great project to get stuck into.
Enjoy
Bryan
1979 z650 c3 first registered in 1981
2006 Harley Davidson VRSCR
Northern Ireland
Were do you start 31 Jan 2010 16:16 #345678
  • MFolks
  • MFolks's Avatar
  • Thank you received: 540
1.New brake lines.
2.New brake fluid.
3.New tires.
4.Clean inside of fuel tank, possibly using a sealer afterwards(sometimes car radiator shops can boil out gas tanks).
5.Remove carbs as an assembly and throughly clean them.
6.Replace control cables(clutch, and throttle).
7.Replace drive chain and sprockets.
8.Replace front fork springs.
9.Replace rear shocks.
10.If the bike has ignition points, upgrade to a Dyna "S" if possible
11.Replace the igniton coils.
12.Replace the sparkplug wires(high tension leads).
13.Replace the battery.
Just a few things I can think of..................
Were do you start 31 Jan 2010 16:52 #345689
  • Kawickrice
  • Kawickrice's Avatar
  • Thank you received: 18
It is not uncommon for these bikes to fire up with a carb and tank cleaning and an oil change after sitting 20 years.
It would help to know why it was parked to begin with but you have to start somewhere so I would get fresh gas to clean carbs and see what happens.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Were do you start 31 Jan 2010 18:24 #345732
  • TerryK
  • TerryK's Avatar
Oh boy, you have your work cut out for you on that one! Is that rust on the fork tubes?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Were do you start 31 Jan 2010 18:55 #345747
  • Kawickrice
Mine sat for 13 years outside and was in bad shape, rusted fork tubes too, could not even roll it, had to cut the chain with a sawsall. It took me 9 months and countless hours and countless dollars to get back on the road but I prevailed. Mine was complete with not a bolt missing so I was able to clean and salvage alot untill I could replace parts. I still have some rusty bolts that I havent replaced yet but that does not compromise safety but is ugly at least. It will be costly no matter what but that is a Z1 so if it were me I would go for it and revive a piece of Kawasaki history
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Were do you start 31 Jan 2010 19:32 #345751
  • jimmybon
perhapes a list with what I'm able to keep would be eazyer
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
Were do you start 31 Jan 2010 19:52 #345753
  • jimmybon
That is definitly rust on the tubes, wheels and tinware. I think they will have to be replaced
It was stored through lack of interest, I would say, In a little town called Yenda NSW Australia, If you have ever had a wine called Yellow Tail, its made in Yenda
here's another pick
Thanks for the tips
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
Were do you start 01 Feb 2010 07:18 #345814
  • Kawickrice
Lots of $$$$$ to get it back to ridable condition. All the chrome is probably shot but the aluminum will polish to a mirror shine. All rubber and cables will need to be replaced I did one section at a time
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Were do you start 01 Feb 2010 10:09 #345835
  • henrymski
  • henrymski's Avatar
$$$ is really dependent on how much you are able to do yourself. Some things you probably just can't do yourself, like getting the forks re-hard chromed.
The first thing you should do is decide if you want to do a concours type restoration, or make it a bash around commuter or somewhere in between. If going for the high-end resto, you'll want to use as much original stuff as possible. Otherwise, you can go with parts from most Z years with out too much problem.
Were do you start 01 Feb 2010 14:08 #345870
  • Galactica
  • Galactica's Avatar
My 76 A4 was in almost the same condition as yours. My fork tubes were OK. If you want to get it ridable until you can do some more resto, start with stuff you can do your self. Put it on the centre stand. Use a jack to lift the front wheel. Remove every thing you can and wire wheel the rust off. Even if the chrome is pitted, use it until you can find better. Go thru the carbs and ignition. Probably need new carb boots and holders. Rebuild break calliper, new lines. New chain, tires, battery, cables.
Great score!! Well worth the effort.
77KZ1000
76 KZ900
  • Page:
  • 1
  • 2
