A little bit of an upgrade... 20 Sep 2011 10:12 #478020
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
  • Thank you received: 109
Bdog wrote: Well the bolt from Fastenal was a 1.75 pitch, but the length is right. Soooooo, now the hunt continues and I am afraid that I will have to have a $2 bolt get shipped for $8-9. I will try a local spot tomorrow that usually has a little of everything. We'll put that to the test.
how about a threaded rod, then cut it to size ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
A little bit of an upgrade... 21 Sep 2011 11:37 #478288
  • Bdog
  • Bdog's Avatar Topic Author
  • Sweep the leg johnny!!!
  • Thank you received: 9
Well if I could find the appropriate size and pitch in threaded rod, I would hope I could find just a bolt the right size. :unsure:
This is how I want to run my foot controls. A little bit stock, a little bit custom, and relatively simple. I need the longer bolt to run through the brake lever (which will need a spacer to work) and the peg hanger. I think it will be pretty cool when done, I was getting a little tired of the rear set pegs.
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
A little bit of an upgrade... 10 Mar 2017 12:48 #756337
  • Bdog
Bringing it back to life this Summer.
New wiring is nearly done, just have to wire brake light and head and tail lights. Caliper rebuild kits and fork seals ordered, and just need to order measure and order brake lines.
Getting excited!!
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
A little bit of an upgrade... 11 Mar 2017 07:42 #756413
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Looks good!
B)
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
A little bit of an upgrade... 17 Mar 2017 10:04 #756935
  • Bdog
Doesn't look like much here, but the fork were rebuilt last night and the majority of the wiring has been completed. Gauges have been mounted and front wheel/tire has been cleaned.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
A little bit of an upgrade... 21 Mar 2017 05:20 #757289
  • Bdog
To do list:
-Muriatic the tank
-rebuild front calipers
-connect brake lines
-build undertail fender
-wrap wiring
-install H4 headlight
-find an appropriate license plate light and plate bracket
-get brake pads (F/R)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
Last edit: by Bdog.
A little bit of an upgrade... 22 Mar 2017 11:06 #757407
  • Bdog
Finally got the pistons out...
They are in good shape, just dirty. Now to clean everything up this evening.
I had to rig a master cyl up to pump out the pistons, as air wasn't cutting it.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
A little bit of an upgrade... 23 Mar 2017 06:45 #757458
  • Bdog
Pain in my ass...
I finally got 8 usable pistons out of 2 sets of Tokico calipers from the 95-97 ZX-6R front end. But I had to drill out holes in the back side of the calipers to push them out. Between corrosion and galling the finish with the pliers, most of the pistons weren't any good.
Hopefully going back together tonight.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
A little bit of an upgrade... 24 Mar 2017 07:41 #757543
  • Bdog
Front end reassembled, just waiting on the new H4 headlight assembly to be delivered...
Luckily the brakes went back together MUCH easier than they came apart!
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
A little bit of an upgrade... 25 Mar 2017 06:06 #757600
  • rstnick
  • rstnick's Avatar
Nice.
Also working on brakes, but stock stuff.
Still a pain trying to salvage used parts at times.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
The following user(s) said Thank You: Bdog, GPz550D1
A little bit of an upgrade... 27 Mar 2017 07:19 #757812
  • Bdog
Got some more stuff done this weekend, made up a quick front stand to be able to remove the swingarm for a bit of work.
Received my box from Z1Enterprises with H4 halogen "sealed beam" headlight to replace the old one and a rear view mirror to pass inspection.
And then yanked the swingarm to have 1/8" or so removed from the face of the sprocket carrier to get chain run straight and start on mounts for the rear fender/mudguard/undertail for the tail section.
Little bit of body filler on the edges and a few chips and it will be ready for some new black, I will hit the side covers while I am at it.
More to come soon.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
A little bit of an upgrade... 29 Mar 2017 09:27 #758032
  • Bdog
Clearanced the swingarm chain guard and reinstalled that last night so the bike is fully supported again. Having the Jack under it was nerve racking as all get out. Bled brakes in the front last night and got pads installed, so the front is fully finished. I am waiting for the sprocket hub to return from the machine shop and I will go ahead and match the paint to the front, sort of a gun metal grey. Rebuild rear caliper, finsh tail section, and buy a chain and I think this thing is ready!!
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
